Harmony Ultimate, Smart Control and Hub - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
Old 07-25-2014, 11:33 PM
EvilAlwaysWins's Avatar
Quoted: 12 Post(s)
Liked: 29
I just installed my new oppo bdd-103d player today and have been working on setting up my Harmony ultimate remote. I am having trouble with the volume control. When Im in movie mode watching a bluray it does work and changes the volume on the reciever. If I watch Netflix or youtube the volume control changes on the oppo player and not the receiver like it should. How can I make it work correctly?
Any help would be awesome.
Forgot the add the onkyo is selected to control the volume in movie mode.
EvilAlwaysWins is offline
Old 07-26-2014, 01:49 AM
Joseph S's Avatar
Quoted: 12 Post(s)
So the Harmony Ultimate supports the Nest...
UNLESS you have 15 devices already for which I'm out of luck. I already had to consolidate multiple switching devices into one.
Once again, please get rid of the device limits.
I own an Ultimate and the "Smart Keyboard," but have to create a new profile for my new Harmony Smart Control for the other room because it has a different TV model and a sound bar and thus I have to start from scratch again because I can't have 17 devices.
How about 15 devices if you own the ultimate, 15 more if you get a second, 8 more if you buy the keyboard, and 8 more for any other remote?
It would be one thing if we could truly buy a couple of devices to cover everything, but we can't.
WMC is only reliable solution for TV recording for HTPC. AppleTV can't do Amazon Prime, Amazon Fire TV can't do Plex with surround sound, Roku can't seems to want to buffer forever before a movie from Plex. Who knows what AndroidTV will bring. WiiU can't play the Gamecube games the Wii can. PS4 and XBox One can't play each other's games. Some movies still aren't out that are on LD, and may never be. Receivers don't have a decent amount of HDMI inputs, so we need additional switchers.
Name:	Screen Shot 2014-07-26 at 12.34.31 AM.png
Joseph S is offline
Old 07-26-2014, 02:21 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
I still don't understand why you need all those streaming devices. If your PC is connected to your TV, why do you need Plex in the same room? Do you really need to control all those game machines from your remote? Are you trying to control everything in your house with one remote? Why not have one remote per room (system)? I have lots of game systems too, but I have no reason to control them with my remote because it's a simple matter to just add on/off to an existing device if I need it, and make a variation of a "Watch TV" activity to handle the input switching and all the rest. When was the last time you actually watched a LD? If I were you, I'd try to simplify.
mdavej is online now
Old 07-28-2014, 04:43 PM
anmg's Avatar
Quoted: 65 Post(s)
sony projector with harmony ultimate
I am using a Harmony Ultimate with my Sony vpl-vw600es projector. The projector has 2 hdmi inputs. All controls seem to work fine except when I want to set a command switch from hdmi 1 to hdmi 2 or 2 to 1. There is no response to this command. Has anyone else come across this issue?
anmg is offline
Old 07-28-2014, 06:23 PM
DoctorVideo's Avatar
Quoted: 16 Post(s)
I have the Smart Control, which I believe works similarly to the Ultimate. With my system, I would need to set-up a separate activity for the device that is plugged into HDMI 1 and HDMI 2. For instance, if your cable box is plugged into HDMI 1, you would set-up a "Watch TV" activity for that device, and if your Blu-Ray player is plugged into HDMI 2, you set-up a "Watch Movie" activity for that device.
DoctorVideo is offline
Old 07-28-2014, 06:25 PM
Quoted: 16 Post(s)
I should add that you can also program an unused button on the remote to switch inputs.
Old 07-29-2014, 08:59 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I agree with DoctorVideo. Why are you sending this command? Or do you mean the activity doesn't have the input change?
NickTheGreat is offline
Old 07-29-2014, 09:50 AM
anmg's Avatar
Quoted: 65 Post(s)
I am using a 4k media player that plugs into hdmi 2 on the projetor and all my other devices use hdmi 1. The media player must go directly to the projector all other devices go through the receiver and then to hdmi 1 on the projector. The only button on the sony projector remote is input. To switch inputs you most press input once to bring up the sub menu and then press input again to switch from hdmi 1 to 2 or 2 to one. So 2 presses of the input button will change the input from 1 to the other. No discrete buttons for hdmi 1 or 2. I can't figure out how to incorporate this into my activities.
anmg is offline
Old 07-29-2014, 10:48 AM
mdavej's Avatar
Liked: 940
Sony is usually very good about having discretes. Have you checked remotecentral.com? If I run across them, I'll post them.
Old 07-29-2014, 11:21 AM
anmg's Avatar
Quoted: 65 Post(s)
Thank you!
anmg is offline
Old 07-29-2014, 11:35 AM
anmg's Avatar
Quoted: 65 Post(s)
I found these.
Input: HDMI 1
Device Code: 84 Function: 111
0000 0068 0000 0010 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 02FD
Input: HDMI 2
Device Code: 84 Function: 112
0000 0068 0000 0010 0060 0018 0018 0018 0018 0018 0018 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0345
How do I use them or incorporate them in into my Harmony Ultimate codes for the Sony Projector?
anmg is offline
Old 07-29-2014, 08:02 PM
mdavej's Avatar
Liked: 940
Thank you!
Here are all the input codes I could find:
http://www.hifi-remote.com/sony/Sony_proj.htm
Code:
Protocol=Sony15 Device=84 Function
Device Code: 54 Function: 2A
0000 0068 0000 0010 0060 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0345
Device Code: 54 Function: 2B
0000 0068 0000 0010 0060 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 032D
Device Code: 54 Function: 2C
0000 0068 0000 0010 0060 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0345
Device Code: 54 Function: 5F
0000 0068 0000 0010 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 02FD
Device Code: 54 Function: 6F
Device Code: 54 Function: 70
Email those to support to add to your account and test. It's possible they don't work at all on newer models, but it's worth a try.
Old 07-29-2014, 08:03 PM
Skrill's Avatar
Quoted: 246 Post(s)
Liked: 73
Harmony Sylvain (or anyone else with a tip)
My two month old Harmony Ultimate remote has developed an sticking 'DVR' button. I.e., it responds to a press, but it does not move much or have the same tactile feel that the other buttons do. It almost feels like whatever normally provides feedback or resistances to the button has failed.
The remote is in a dedicated theater and there have been no children (or adults) with grubby hands handling the remote. Are their any quick fixes you might suggest short of seeking warranty assistance? I hate being without my remote ... :-(
CT
Skrill is offline
Old 07-30-2014, 02:22 AM
pmcd's Avatar
Quoted: 13 Post(s)
I have a Smart Control with the basic remote but have not gotten around to using it because of the 8 device limitation. So I use a One which has developed two unresponsive buttons.
If you get the Smart Control keyboard and use it with the Hub does that increase the number of device that can be used ( 8 with the basic remote and more with the keyboard)?
Finally, there is now an Ultimate One. Can it be used with the Hub in a mixed fashion ( some ir some rf)? Sounds like the older Touch.
Forgot, does the iPhone app or hub keyboard act like a Bluetooth keyboard with trackpad for controlling a Mac Mini or win8 computer hooked up to the TV?
Philip
pmcd is offline
Old 07-30-2014, 07:26 AM
ParityBit's Avatar
Quoted: 112 Post(s)
I have a quick question ...
What is the difference between the Ultimate and the Ultimate One? Is it just the hub, but the remote is the same?
Is there a 'vs' out there so I know what I will be missing if I do not get the Ultimate?
ParityBit is offline
Old 07-30-2014, 08:07 AM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
The Ultimate includes the Hub, the Ultimate One is a stand alone remote without the Hub and replaces the Touch.
rehaz1 is offline
Old 07-30-2014, 08:15 AM
ParityBit's Avatar
Quoted: 112 Post(s)
Old 07-30-2014, 08:22 AM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
Philip
I originally had the Smart Control in my Bedroom and an old Harmony One in my living room. My One finally crapped out so I bought a Harmony Ultimate for the Living Room and ended up loving it, which prompted me to want to upgrade my Smart Control in the bedroom. I was sick of having to use my phone and the basic remote not being backlit so I bought a Harmony Ultimate One. Install was pretty straight forward; you just install the Ultimate One, copy all the setting over from your Smart Control, then go into the settings in the software and choose Upgrade this remote. This will walk you through adding the Hub from your Smart Control to the Ultimate One which gives you control of 15 devices. I have not found anything too different between this setup and the Harmony Ultimate package except when you make changes to the Ultimate One in the software you still have to plug it in to your PC.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
Old 07-30-2014, 08:28 AM
sikclown's Avatar
Liked: 691
I have both and used the Ultimate One along with the Smart Control I already had to upgrade to basically the full Ultimate One. Only difference I can find is I have to plug my Ultimate One in when I make changes in the software vs my Harmony Ultimate just updating. Added functionality with the full Ultimate are control Bluetooth consoles like PS3, turning the remote's RF into IR and Bluetooth commands, Some control of IP device like Hue (the seem to be adding more to the list), actually having RF vs the Ultimate one only having IR (so you need IR blasters for anything out of the way).
sikclown is offline
Old 07-30-2014, 08:48 AM
ParityBit's Avatar
Quoted: 112 Post(s)
Sounds like I need to ultimate to control my Xbox One. When will it do the PS4? Also, where do you put the hub?
Old 07-30-2014, 09:15 AM
sikclown's Avatar
Liked: 691
In my living room I put my Hub kind of center of my entertainment center on bottom shelf and run two IR extenders to each side but not even sure I need them. Everything works perfectly including XboxOne. Not sure when PS4 will add the ability to use bluetooth remotes but Harmony will likely add support as soon as Sony does (if Sony does).
Oh and I am not sure you NEED Ultimate to control Xbox One. Pretty sure Ultimate One will control it as long as you have a Kinect. You just have to point the Remote directly at the Kinect. I could be wrong about that though.
sikclown is offline
Old 07-30-2014, 09:40 AM
ParityBit's Avatar
Quoted: 112 Post(s)
So if I were to get one, the only place I could put it is in one of the sides of the entertainment center behind a glass door. Would that work if I made it visible? Does it come with extenders or would I not really need them?
I was going to order a remote tonight so I get it for the weekend.
Old 07-30-2014, 10:07 AM
sikclown's Avatar
Liked: 691
The remote talks to the hub via RF so you can put the hub anywhere and not worry about having to point your remote at it. I haven't pointed my remote at anything since purchasing really. Your mileage may vary but the hub is one big IR blaster and the signal gets around pretty well. Experiment with the best spot for your hub. It comes with two mini IR blasters.
sikclown is offline
Old 07-30-2014, 10:28 AM
ffrcoupe's Avatar
Dear Harmony,
Stop turning vibration back on every time I sync my Ultimate.
TIA.
Edit: I guess you can add screen lock to that too.
ffrcoupe is offline
Old 07-30-2014, 11:18 AM
ParityBit's Avatar
Quoted: 112 Post(s)
Excellent! I ordered the Ultimate. Thank you for the help. Hopefully I can come back here talking about how awesome it is, rather than all my stupid questions
sikclown likes this.
Old 07-30-2014, 11:35 AM
sikclown's Avatar
Liked: 691
Originally Posted by ffrcoupe View Post
Dear Harmony,
TIA.
I second these. Lock screen is so annoying.
sikclown is offline
Old 07-30-2014, 11:37 AM
sikclown's Avatar
Liked: 691
You're welcome and no such thing as stupid questions. I came here myself to ask how to upgrade Smart Control
sikclown is offline
Old 07-30-2014, 11:49 AM
Quoted: 381 Post(s)
Liked: 255
Thirded
Old 07-30-2014, 12:53 PM
pmcd's Avatar
Quoted: 13 Post(s)
I have decided to replace my One with the Ultimate One. I assume this will then raise the number of devices of my Smart Control Hub to 15. If I then get the new Smart Control Keyboard AddOn will that do anything to the number of devices I can control? I have a Mac Mini and a NUC attached to the TV. Both have Bluetooth. This device limitation is a bit of an inconvenience. As more AddOns are developed it will only be worse.
Philip
pmcd is offline
Old 07-30-2014, 03:50 PM
sikclown's Avatar
Liked: 691
Philip
I think the Smart control keyboard has it's own hub. Not sure if it can be added to the same one as an Ultimate One. 15 devices is the max any one hub or remote can control.
sikclown is offline
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
