Harmony Ultimate, Smart Control and Hub - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 128Likes
post #2431 of 3761 Old 12-04-2014, 05:10 PM
KOTULCN's Avatar
Anyone have an issue with their ultimate "ok" button not working unless you press it a certain way? I have to push it towards the up position to get it to work. I've had this issue before on my iPhone's Home button which ultimately required the phone to be replaced.
KOTULCN is offline
post #2432 of 3761 Old 12-04-2014, 05:10 PM
cuzed2's Avatar
Quoted: 197 Post(s)
Liked: 254
Can anyone help me with the following:
How does one change the name or title of a button/function on an activity screen?
My "Watch TV activity" includes control of my Dish network DVR. The "button" for access to the DVR menu is called "LIST". Is it possible to rename a button (would prefer to rename this from "LIST" to "DVR") ?
Perhaps what I am is asking above,(renaming a button); cannot be done?
I am also OK with the "not possible"response...
Thanks in advance for ANY response
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #2433 of 3761 Old 12-04-2014, 07:20 PM
bweissman's Avatar
Quoted: 230 Post(s)
Liked: 89
It can be done in the Buttons sections of the MyHarmony application. You can relabel any soft button.
bweissman is offline
post #2434 of 3761 Old 12-04-2014, 07:43 PM
cuzed2's Avatar
Quoted: 197 Post(s)
Liked: 254
Thank You!
I was on the MyHarmony app but somehow missed it. I'll give it another try-appreciate your help !!!!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #2435 of 3761 Old 12-04-2014, 09:57 PM
vancouver's Avatar
Quoted: 53 Post(s)
Liked: 31
Originally Posted by NickTheGreat View Post
I can't follow the logic flow of that. If the device isn't the activity, you shouldn't be using it in that activity.
Can't you include a device, but not have it do anything at startup? Maybe that's exactly what you're asking. If so I apologize.
If I include it then it's required to always turn on when I start the activity. In my case it's an external device I onky want on sometimes so I want to have access to the power toggle and a couple other functions.
vancouver is offline
post #2436 of 3761 Old 12-04-2014, 10:09 PM
mdavej's Avatar
Quoted: 2167 Post(s)
Liked: 953
You can configure any device to not power on in activities. You can also manually add functions from any device whether it's in the activity or not. At least this is how Harmony software used to work on other remotes.
mdavej is offline
post #2437 of 3761 Old 12-07-2014, 07:55 PM
cgott42's Avatar
Quoted: 142 Post(s)
How Do I program an Alt-F4 combo keypress to my Harmony Smart Control (I have the Microsoft MCE-Keyboard devices). When I add a sequence it doesn't do the combo, but rather one key then the next.
thx
cgott42 is offline
post #2438 of 3761 Old 12-10-2014, 08:56 PM
Jasonn B's Avatar
Quoted: 320 Post(s)
Liked: 121
I have a Harmony 890 that I've had for over 7 years which has RF. I've dropped it so many times that probably 7-8 buttons no longer work. I've been looking at this new smart hub.
I called into Harmony and told them I didn't want a remote and just wanted to use my Iphone 5 to control everything. They said all I'd need is the $99 hub and the smart phone app. Is this true?
1) They said as long as I can get a blaster to the tv remote window, I can control the tv and the cable box, etc, that is hidden in the cabinet. Is this true?
2) I have about 10 activities in my harmony 890. Can I still do as many?
3) Isn't anyone solely using an ipod or iphone to control everything, instead of having an actual remote?
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #2439 of 3761 Old 12-10-2014, 09:22 PM - Thread Starter
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Yes, what they told you is true. The hub itself has IR, and the then you an hook blasters to it or with the appropriate adapters you can do direct IR input for devices that support that.
I don't know the limit on activities off-hand, it's probably in the faq, I believe it varies based on which package you purchase from them.
I personally wouldn't use just a phone or tablet. At the very least get the Smart remote version, it's a nice, light-weight remote, and with the short and long push buttons you get a lot of control. I use an Ultimate in the theater and a Smart in the family room, where my interaction with the system tends to be more basic, and I love the Smart for basic tasks.
Keith Mickunas is offline
post #2440 of 3761 Old 12-11-2014, 05:49 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
#1 is true. I have my hub sitting in a closet (door closed) on top of my AVR. It controls my AVR, BP, STB, Wii I could have allowed the hub to control the TV if the mini blasters were connected to the hub but I did not want to run that wire outside of the closet door. Instead I just changed my "HUB AND REMOTE ASSIGNMENTS" for my TV to "REMOTE". This way my Ultimate remote will send IR to that TV (I know you said you did not want a remote). As far as the app goes using my phone, I cannot control the TV now, so I just use the remote.
#2 . Yes. You are only limited to the number of "DEVICES" you have and that is 8 for the hub only http://myharmony.com/products/detail/home-hub/ and with the Ultimate/Hub remote system you can control 15 devices http://myharmony.com/products/detail/ultimate-home/ You don't have a limit on "Activities" on either one.
#3 . Not me
CaptMike is offline
post #2441 of 3761 Old 12-11-2014, 05:57 PM
cuzed2's Avatar
Quoted: 197 Post(s)
Liked: 254
#3 . Not me
Jasonn B,
I have the smart-control-hub setup. I am controlling the hub by an orignal i-pad, that I have "re-purposed" as my new "dedicated remote". Although many don't care for the touch-screen, I am just fine. Haven't used the smart remote in about a year.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #2442 of 3761 Old 12-12-2014, 07:19 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Wow...since when did Harmony start charging $10 per incident for phone support if their remote is over 90 old?
CaptMike is offline
post #2443 of 3761 Old 12-12-2014, 07:54 AM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
Pet harmony peeve.
Macro's aren't shared between activities, so I have to remake make them for each activity I need them in..
TorTorden is offline
post #2444 of 3761 Old 12-12-2014, 09:04 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
FIX FOR ANYNET COMMUNICATION PROBLEMS BETWEEN SAMSUNG TV AND YAMAHA AVR
1. Add and additional command (AVR input) to the Activity sequence following this http://support.myharmony.com/en/teac...issing-command and once you have done that....
2. Go into your Activity on myharmony and click CUSTOMIZE THIS ACTIVITY.
3. From there, click on ADD STEP at the top of that page and SELECT YOUR DEVICE from the drop down box
4. Then in the ACTION column, select COMMAND in the SELECT ACTION drop down
5. In the VALUE column, select your newly named command from step 1
6. Click SAVE
You many need to also add a delay BEFORE your newly added command (as I did)
To do this:
1. Select ADD DELAY at the top of the CUSTOMIZE THIS ACTIVITY page
2. Use the up/down arrows located in the VALUE field to select your delay time or just click in that field and enter the number from your keyboard.
3. Click SAVE
Note that you can do these 2 procedures in any order, as you can reorder the delay you have created to be BEFORE the your newly added command using the reorder horizontal bars to the left of the ORDER column.
Pay it Forward
CaptMike is offline
post #2445 of 3761 Old 12-14-2014, 05:43 AM
1C5
1C5's Avatar
Quoted: 13 Post(s)
Does the remote connect to the hub through wifi or Bluetooth?
I have the hub in the basement with my rack and am trying to use the remote in the family room. I'm getting lots of "unable to connect to hub" errors when using the remote. Is there anything I can do to help this outside of moving the hub closer to remote? (This is not possible in my setup)
1C5 is offline
post #2446 of 3761 Old 12-14-2014, 06:54 AM
Joseph S's Avatar
Quoted: 12 Post(s)
Bluetooth AppleTV support broken in latest version:
SmartKeyboard and Ultimate sending navigational keys by IR and esc/trackpad by bluetooth. Have tried resetting to defaults, adding/removing device and activity. There is no way to select which way to send the command which would solve this issue should it happen again.
Joseph S is offline
post #2447 of 3761 Old 12-14-2014, 07:17 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
The communication between the remote and hub is RF
The issue is not " moving the hub closer to remote" it would be moving the HUB closer to the router.
CaptMike is offline
post #2448 of 3761 Old 12-14-2014, 07:38 AM
1C5
1C5's Avatar
Quoted: 13 Post(s)
Thanks. The hub is right next to my router and the remote is still losing connection to the hub when I try to start activities. Any idea what the issue might be?
1C5 is offline
post #2449 of 3761 Old 12-14-2014, 07:45 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
1. Has this happened in the past?
2. Try pulling power from the hub...wait about 1 min...then reconnect power back to the hub...wait for the green light to illuminate steady on the hub and try again with the remote.
CaptMike is offline
post #2450 of 3761 Old 12-14-2014, 07:54 AM
1C5
1C5's Avatar
Quoted: 13 Post(s)
The error says "unable to reach hub. Bring remote closer to hub"
I just got the remote and it's been giving me this issue for a few days.
I did try pulling the power from the hub. No help.
1C5 is offline
post #2451 of 3761 Old 12-14-2014, 08:07 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Interesting. So then as I understand it, you have never been able to use your remote/hub?
CaptMike is offline
post #2452 of 3761 Old 12-14-2014, 08:18 AM
1C5
1C5's Avatar
Quoted: 13 Post(s)
It starts my activity properly maybe 30% of the time. The other 70% it loses connection to hub and won't start the activity properly.
Very strange. Just wondering if there may be something simple to fix it or if I have to return it and try another remote solution.
1C5 is offline
post #2453 of 3761 Old 12-14-2014, 08:25 AM
dvdmd1's Avatar
Quoted: 42 Post(s)
Liked: 56
I had the same connection problems too,turns out it was my router.I had to replace it and it's been working flawlessly ever since.
dvdmd1 is offline
post #2454 of 3761 Old 12-14-2014, 08:43 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
What other devices are connected to your wireless network?
CaptMike is offline
post #2455 of 3761 Old 12-14-2014, 08:46 AM
1C5
1C5's Avatar
Quoted: 13 Post(s)
I just moved into a new house so I have only my Lennox furnace controls hooked to the router, Apple tv, sonos, my Marantz receiver and an iPad and a couple iPhones.
1C5 is offline
post #2456 of 3761 Old 12-14-2014, 08:59 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Well, now I'm stumped.
I do have some communication issuse with my hub on occasion, but every time that happens..a power cord pull and reconnect has resolved the issue.
CaptMike is offline
post #2457 of 3761 Old 12-14-2014, 04:36 PM
asarose247's Avatar
Quoted: 759 Post(s)
Liked: 534
Sooooo . . . help me complete the following, as a new owner/user of the smart remote . .
my hub should / will function best when connected or near my AVR, entertainment center console
does it need to be connected to the TV for visuals?
the intro to this thread is excellent reading but it gets long
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #2458 of 3761 Old 12-14-2014, 04:58 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Not sure what you mean by: "does it need to be connected to the TV for visuals?"
CaptMike is offline
post #2459 of 3761 Old 12-14-2014, 09:54 PM
asarose247's Avatar
Quoted: 759 Post(s)
Liked: 534
how will I see what I'm doing just asking
ow kinda lost
post #2460 of 3761 Old 12-14-2014, 10:23 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
ow kinda lost
Do you mean..does it have a GUI?
CaptMike is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
