Harmony Ultimate, Smart Control and Hub - Page 83 - AVS Forum
 20Likes
post #2461 of 2479 Old 12-15-2014, 05:17 AM
asarose247's Avatar
Quoted: 82 Post(s)
Liked: 57
yes-?
Denon X5200 , Emotiva UPA7, for 7.3.4 ATMOS/DSU
Klipsch FL/FR: F3 , Center: Icon 25 , SL/SR: RC3II , SRL/SRR :Icon 36 Towers, TF & TR: SLX
FH :RB51's
2 30" BF THTLP'S and SUBMAXIMUS and Inuke6000DSP
SHARP 80" LED/LCD, Xbox1 PS4 Panny BD 220
asarose247 is offline
post #2462 of 2479 Old 12-15-2014, 07:45 AM
CaptMike's Avatar
Quoted: 206 Post(s)
Liked: 44
Originally Posted by asarose247 View Post
yes-?
There is no GUI
Read the manual for set-up and use myharmony app on your computer to set it up
Samsung UN65HU8550FXZA TS02, X-10 lighting, IR543 Powerhouse Command Center
Yamaha TSR-6750WA
Sony S6200
Dish 211K
JM lab speakers
Harmony Ultimate remote
CaptMike is online now
post #2463 of 2479 Old 12-15-2014, 10:15 AM
NickTheGreat's Avatar
Quoted: 154 Post(s)
Liked: 107
Originally Posted by TorTorden View Post
Pet harmony peeve.
Macro's aren't shared between activities, so I have to remake make them for each activity I need them in..
THAT would be nice. If it worked kinda like Tasker for Android in that regard.
NickTheGreat is offline
post #2464 of 2479 Old 12-15-2014, 11:50 PM
asarose247's Avatar
Quoted: 82 Post(s)
Liked: 57
progress report
got the harmony app on the galaxy s-5 AND my tablet
spent some time unlearning my mistakes and then some quality time pointing my remotes at the hub
much better
thanks for the support and
a shout out to Manaj, a fellow LA area enthusiast for his patience and great shopping skills . . .
FH :RB51's
post #2465 of 2479 Old 12-16-2014, 05:34 AM
CaptMike's Avatar
Quoted: 206 Post(s)
Liked: 44
You do not have to point the remote at the hub, the remote is RF
Yamaha TSR-6750WA
Sony S6200
Dish 211K
JM lab speakers
post #2466 of 2479 Old 12-16-2014, 06:09 PM
47okie's Avatar
I'm still programing my Ultimate after about 8 months, but I'm very happy with it. My Yamaha RX-A830 remote requires that I move a slide switch from "Main" to "Zone2" in order to choose a separate source and adjust volume on the speakers throughout the rest of my house. Is that a command that I'm going to be able to program on my Ultimate? I've already put "Party" mode on the Ultimate - this turns on the main listening room, and the rest of the house (Zone2) at the volume level it was set to when it was last turned off - but this mode doesn't enable volume control in Zone2. Thanks for any help with this.
47okie is offline
post #2467 of 2479 Old 12-16-2014, 09:56 PM
mdavej's Avatar
Quoted: 619 Post(s)
Liked: 447
When you move the switch, your remote sends an entirely different set of commands, which can be learned if necessary. But usually adding a 2nd device and confirming a few zone 2 commands is sufficient for Harmony to load the entire set. Support can probably tell you exactly what device model name to use to get the zone 2 commands without the confirm step. That's how multi-zone is typically handled on Harmony remotes.
mdavej is offline
post #2468 of 2479 Old 12-17-2014, 06:56 AM
rehaz1's Avatar
Quoted: 20 Post(s)
To add Zone 2 control, add your Yamaha device a second time to your account, when adding the model number, add (Zone 2) to the end of the model number just as I typed it with out the bolding
rehaz1 is offline
post #2469 of 2479 Old 12-17-2014, 12:10 PM
47okie's Avatar
Thanks for the tip, I'll try that.
After adding the Yamaha with the (Zone2) tag, what buttons will I have to add for display on the remote?
47okie is offline
post #2470 of 2479 Old 12-17-2014, 01:15 PM
rehaz1's Avatar
Quoted: 20 Post(s)
After you create a Zone 2 Activity, any missing commands on the LCD display can be added manually
rehaz1 is offline
post #2471 of 2479 Old Yesterday, 09:45 PM
47okie's Avatar
Thanks, I got the Zone2 version of the device added and now I can control Zone2 volume from the remote. Any thoughts on how best to integrate Zone2 control into my activities? Has anyone written on this subject?
47okie is offline
post #2472 of 2479 Old Today, 10:58 AM
pbc
pbc's Avatar
Quoted: 52 Post(s)
Liked: 38
I have components in a triple 20 Salamander rack with my processor on one side (with an amp) then my Blu-ray player and cable box on the other side (with another sub amp).
Does the hub come with just the two sides and therefore won't work on this sort of system without moving all the components to one side (which I don't think will fit due to heat issues)?
pbc is offline
post #2473 of 2479 Old Today, 12:11 PM
jnnt29's Avatar
Liked: 51
Not sure what you mean by two sides. I have the hub in a cabinet with my amp and Blu Ray on one side my AVR in the center and cable box and Roku on the other side and it works fine. You should have no problem with your set up. There also two mini blasters that you can position to control devices that the hub doesn't reach.
jnnt29 is online now
post #2474 of 2479 Old Today, 12:49 PM
pbc
pbc's Avatar
Quoted: 52 Post(s)
Liked: 38
The unit is essentially like this with 3 distinct compartments, left, right and middle.
In the middle I have media drawers.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #2475 of 2479 Old Today, 12:51 PM
CaptMike's Avatar
Quoted: 206 Post(s)
Liked: 44
Don't know what you mean by "Does the hub come with just the two sides"
The hub transmits IR all around it
I see that you may have a problem in the picture you provided. With not all components in one section, the hub probably will not reach all devices, you may need to hook up the mini blasters. The possibly saving grace is that the IR from the hub (may) be able to bounce off the back wall since you have glass in those compartments. You can then set the remote to transmit IR only to your TV IF the IR from the hub does not reach the TV.
Oh, is each section divided by with a partition?
Yamaha TSR-6750WA
Sony S6200
Dish 211K
JM lab speakers
post #2476 of 2479 Old Today, 01:19 PM
pbc
pbc's Avatar
Quoted: 52 Post(s)
Liked: 38
Thanks, separated by partitions unfortunately.
pbc is offline
post #2477 of 2479 Old Today, 03:09 PM
pbc
pbc's Avatar
Quoted: 52 Post(s)
Liked: 38
Is it possible to hook up more than one Hub (one on each side) and control with the same remote?
pbc is offline
post #2478 of 2479 Old Today, 03:45 PM
jnnt29's Avatar
Liked: 51
Unfortunately you can only have one hub assigned per remote. My set up in my cabinet is very similar to mine and the only unit that doesn't pick up the hub's signal is the Roku. For the Roku I have a mini blaster on that Side of the cabinet and it work great. Check out my signature to see my cabinet on the last past. JT
post #2479 of 2479 Old Today, 10:02 PM
timmo's Avatar
Roku can now be controlled via IP in the Harmony setup (so IR is no longer required), at least for Roku 3.
timmo is online now
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
