Harmony Ultimate, Smart Control and Hub - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 128Likes
post #2521 of 3761 Old 01-10-2015, 10:56 AM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
Just looked on website you can get the numbered remote for cheap to add to the hub FYI!
azz7686 is offline
post #2522 of 3761 Old 01-10-2015, 11:21 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Originally Posted by JustABrah View Post
Your pretty defensive over a remote control, it's just a remote and one persons opinion, I'm not trashing it or saying I hate it, all I'm saying is that its a cool looking remote that has its trade offs, is that so bad that it got your panties in a bunch?. I knew it didn't have a number key pad, and I knew I may not like that it didn't but I like the smaller size and some of the abilities of the touch screen so I tried it out. Relax its just a remote, no need to get so defensive cause someone doesn't think its the bees knees.
Not being defensive just tying to get into your brain.
You said it does not have a key pad. What about the key pad on the touch screen when a device is added, such as a DTV or DISH STB?
CaptMike is offline
post #2523 of 3761 Old 01-10-2015, 11:24 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
The number keys are dedicated to a particular device (IR code)
In other words, the numbered remote added to the hub will not work for more than one device
CaptMike is offline
post #2524 of 3761 Old 01-10-2015, 12:05 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
The Smart Control Add-on remote requires an existing Harmony Ultimate Hub. Harmony Ultimate Hub is included with Harmony Ultimate, Harmony Smart Keyboard, or Harmony Ultimate Hub.* Smart Control Add-on is not compatible with Harmony Home Hub.
azz7686 is offline
post #2525 of 3761 Old 01-10-2015, 12:08 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
This one connects directly to hub via blutooth no ir!
azz7686 is offline
post #2526 of 3761 Old 01-10-2015, 12:08 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
azz7686 is offline
post #2527 of 3761 Old 01-10-2015, 07:37 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Add on...understand
CaptMike is offline
post #2528 of 3761 Old 01-10-2015, 07:40 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
Add on...understand
Yeah he already has the ultimate with touch and he can just add it,
azz7686 is offline
post #2529 of 3761 Old 01-11-2015, 04:30 PM
davidhoenig's Avatar
Does anyone have any information on when the Harmony Hub Extender is coming out? I haven't seen anything since the September announcement. I really need something help with my light controls in my HT.
davidhoenig is offline
post #2530 of 3761 Old 01-11-2015, 07:43 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
I don't know what remote you have but I have the Ultimate and X-10 home theater lighting and use an IR543 with the remote.
CaptMike is offline
post #2531 of 3761 Old 01-12-2015, 10:54 AM
johnnyray's Avatar
I have X-10 and it works fine with my Ultimate. I use the IR543 and I have a few extras if you need one.
I used the IBM Lighting (IBM HD23) in the myharmony database
If I could have found the IR543 at a reasonable price, I would definitely have preferred to get that because it was actually meant to work with X-10 directly without having to be converted using some kind of method I am not able to get right with this supposedly comparable Smarthome IRLinc device I bought. Weren't' they retailing for around $15 when they were available? I paid over $50 for this used 2411R, so if I can't find any way to actually use it with my Harmony hub and existing X-10 modules I will have to try to return it and take you up on the IR543 offer... Thanks for the response.
johnnyray is offline
post #2532 of 3761 Old 01-12-2015, 11:20 AM
NickTheGreat's Avatar
Quoted: 396 Post(s)
Liked: 268
I spent some time last night trying to integrate my Hue's with this thing. I added it through the software, but i'm not able to incorporate through any activities.
Everything I read talks about doing this through the app and/or through the remote. I did it through the remote, and can turn off/on, but thats it. It won't let me integrate to the activity any further.
Seems like an odd issue. Maybe I need to remove the Hue completely and start over, adding through the remote.
I'd really like to PAUSE a movie, and have the lights come back on. Any other automation I handle through something else.
NickTheGreat is offline
post #2533 of 3761 Old 01-13-2015, 01:57 PM
HarmonySylvain's Avatar
Quoted: 106 Post(s)
Liked: 52
The Harmony Home Hub Extender will be available this spring!
Just a little more patience
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
post #2534 of 3761 Old 01-13-2015, 01:59 PM
Quoted: 106 Post(s)
Liked: 52
The way hue is programmed into Activity start & stop actions is different for Ultimate and Ultimate Home products. On Ultimate, it's done directly on the remote, from the bulb icon. On Ultimate Home, this is done by (re)visiting Activity setup from the Harmony app.
It currently isn't possible to tie home control actions to a specific button press, unfortunately.
post #2535 of 3761 Old 01-13-2015, 02:06 PM - Thread Starter
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Any word on the price and specifications? Will this give the Ultimate all the capabilities of the Ultimate Home? Does it replace the existing hub or work alongside it?
Keith Mickunas is offline
post #2536 of 3761 Old 01-13-2015, 02:09 PM
mustang5o's Avatar
Quoted: 34 Post(s)
Originally Posted by mdavej View Post
Yep, although Ortek works fine with the Ortek profile and for basic commands, but it can't do key combos like a Microsoft dongle can. I use Ortek on all my PCs and Raspberry Pi's running XBMC and they work fine. I simply have no need for combos. The advantage of Ortek is that the dongle is very small and includes a USB extension and wakes my PC properly 100% of the time. I've never been able to find a Microsoft (MCE) dongle that can consistently wake my PC.
Obviously, you must use an Ortek or Adesso profile on your Harmony for it to function at all, as Sylvain said. The Media Center profiles won't work because Ortek uses an entirely different protocol. The Windows Media Center SE profile is totally incompatible with Ortek.
You can also use both an Ortek and Microsoft dongle. I ran that way for a while, using Ortek just for wake and Microsoft for everything else. But even that ultimately failed as my Microsoft dongle driver would sometimes fail to load after a sleep/wake cycle.
Ppilot, if you want to get rid of that Ortek, PM me. I could always use a spare.
Hey there. I'm back with a few more questions about the Harmony Ultimate. I'm thinking about using this with XBMC(Kodi now) and also a Fire TV. From what I've read I need to use something like the Ortek for the FireTV to work properly. I figured I'd also use them for the PC's since they can wake reliably. However, when you program the Hamony Ultimate Home remote for the Ortek profile, does the number keypad work in that profile? One of the things I was really hoping to find is a solution that will allow using the numeric keypad while watching live TV in Kodi (or within the EPG).
Thanks again.
"Like a Ninja, only better!"
mustang5o is offline
post #2537 of 3761 Old 01-13-2015, 08:34 PM
mdavej's Avatar
Quoted: 2167 Post(s)
Liked: 953
Thanks again.
Of course it does. But what does that have to do with Fire TV? The Ultimate controls the Fire TV natively via bluetooth, no IR dongle required.
mdavej is offline
post #2538 of 3761 Old 01-14-2015, 08:46 AM
mustang5o's Avatar
Quoted: 34 Post(s)
Right. OK I think I'm confusing myself with my two different remote setups. Right now I'm using the 650 in my living so with that I'd need the Ortek setup and IR dongle. Although I'd still want to use the Ortek setup with the Ultimate (if I decide to go that route) as that would be controlling a WMC PC with Kodi on it.
post #2539 of 3761 Old 01-14-2015, 08:58 AM
Quoted: 396 Post(s)
Liked: 268
Sigh. Ok, thanks for the reply.
I'm a little disappointed with the amount of "integration" with the Ultimate, but I guess it's better than nothing.
post #2540 of 3761 Old 01-14-2015, 02:18 PM
jdoubleh's Avatar
Quoted: 16 Post(s)
I've got the same questions on this. Hoping Harmonysylvain will respond.
jdoubleh is offline
post #2541 of 3761 Old 01-15-2015, 10:19 AM
pjp
pjp's Avatar
Quoted: 41 Post(s)
I'm trying to use the Smart Control Hub to control my 2-channel stereo from my iPhone 6, but when I set up the "Listen to CD" activity, for example, it defaults to 3 screens of commands. The first screen is a number pad, which is not applicable to my system or CD player, the second screen is transport and volume controls, and the third screen is (drum roll please) -- a single stop button.
What I want is a single scrteen that has only the commands I need. Is there any way to customize buttons on a smartphone? When I go into "My Harmony", I only see options for button customization on the simple remote (which I'm not using). I also don't see any button configuration options in the app itself. I've used many Harmony remotes over many years, but am new to the Smart Control, so I'm probably missing something and would appreciate any advice.
pjp is offline
post #2542 of 3761 Old 01-16-2015, 05:40 AM
pjp
pjp's Avatar
Quoted: 41 Post(s)
Bump: Is there really no solution to configure the buttons on the smartphone? It's actually easier to use the standard remote I am trying to replace than to have to scroll through 3 or 4 separate screens of controls it currently forces me to have on the Smart Control smartphone app.
pjp is offline
post #2543 of 3761 Old 01-16-2015, 11:24 AM
loungesong's Avatar
Recommendation for IR on Home Control
After four years of relatively smooth sailing, my 900 is dying. It constantly crashes, resets, freezes, etc. and after doing everything on the software side I can (firmware resets, restores) I'm giving up. Wife is pretty fed up, too.
I would like to go with the Home Control but without the IR on the remote I'm not sure how I can make it work.
My setup is TV (Samsung UN55D8000) on the wall and all components racked up high in a closed closet. Because there's no way the blasters in the closet can reach the TV, the 900 worked well because of the IR on the remote. There's no way to run one of the stock mini blasters to get line of site, either.
I do have available CAT6 running from the closet to behind the TV. Has anyone adapted a mini blaster to run over CAT6? Is there another option I'm missing? Could I do HDMI-CEC control from my Denon X3000 receiver?
All I really do with the remote is turn the TV on and off.
Thanks in advance!
loungesong is offline
post #2544 of 3761 Old 01-16-2015, 11:43 AM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
I actually have a Samsung un65f7100 on the wall and ended up using a cat 5 same thing for the application but i had to double up pairs for it to work just using one twisted pair did not work for me.
Spoiler!
azz7686 is offline
post #2545 of 3761 Old 01-16-2015, 11:48 AM
loungesong's Avatar
Wow, thanks for the reply. So you just cut one of the mini blaster cords in half, and spliced each wire to the CAT6 (using a pair for each IR blaster wire)? Duh! Why didn't I think of that?
post #2546 of 3761 Old 01-16-2015, 11:53 AM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
I just cur one of the blasters cords to length i needed and wired red to one pair and black to another pair and repeated on the other end and just 2sided taped the blaster eye just below the bottom right corner of tv and has worked fine for the past year now. My closet is about 45' away in the back of the room if that helps.
Spoiler!
azz7686 is offline
post #2547 of 3761 Old 01-16-2015, 02:05 PM
Liked: 1
Maybe someone could help me with an issue related to the wrong input selected by the AV receiver.
I a few words, I conected a Panasonic tv TX-L37E30B, a Yamaha AVR RX-A2040 and an Oppo BDP-103D to three activities: watching tv, movies and listen to music. Everything works fine except one thing: whenever I switch on to watch movies, after I close everything off and restart the watch tv activity, the AVR input starts corectly to TV, but after few seconds moves automatically to AV1 (the bluray player entry).
Do you know why that happens and what's the solution? The fix command on my remote works everytime, but that fix is only temporarily.
Thanks in advance.
travisbest is offline
post #2548 of 3761 Old 01-16-2015, 02:25 PM
Quoted: 106 Post(s)
Liked: 52
If you hit the Menu button from within your Activity and select 'Edit' you'll be able to rearrange the commands as you desire, or add some.
post #2549 of 3761 Old 01-16-2015, 02:25 PM
Rambler358's Avatar
Quoted: 91 Post(s)
Liked: 25
[QUOTE=travisbest;Do you know why that happens and what's the solution? The fix command on my remote works everytime, but that fix is only temporarily.[/QUOTE]
Do you have ARC and/or HDMI link set up on any of your devices? If so, try disabling that and see what happens.
Rambler358 is offline
post #2550 of 3761 Old 01-16-2015, 02:28 PM
Quoted: 106 Post(s)
Liked: 52
Is is an extender - so will only work with the Harmony Hub. It will work with any hub-based Harmony remote - Ultimate, Ultimate Home, Smart Control, Home Control, etc.
I'm not certain on the price, unfortunately, but it will allow direct control of both Z-Wave and Zigbee devices without the need to integrate through another platform such as SmartThings.
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
