Harmony Ultimate, Smart Control and Hub - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 126Likes
post #2701 of 3743 Old 03-25-2015, 04:27 AM
DELTAsnake's Avatar
Quoted: 45 Post(s)
I'm thinking of upgrading from a Harmony Touch to an Ultimate. Just wondering about placement of the Hub and IR blasters and if what comes in the box will cover me.
I have an open entertainment center with 3 shelves. AVR is on the bottom. Xbox One and Xbox 360 slim on the next level which both often don't turn on with my Touch. Apple TV and Satellite box and two non-IR consoles on the next shelf. TV is on the wall above.
Will the included Hub and IR blasters be able to cover all of this? Any potential problems?
Samsung UA55HU9000, Samsung HW-J7500, Xbox One, PS4, Wii U. Plus a bunch of old consoles.
XBL: DELTAprime, PSN: DELTAsnake, Wii U: DELTAprime
DELTAsnake is offline
post #2702 of 3743 Old 03-25-2015, 07:08 AM
jnnt29's Avatar
Quoted: 118 Post(s)
Liked: 132
[QUOTE=DELTAsnake;32915081]I'm thinking of upgrading from a Harmony Touch to an Ultimate. Just wondering about placement of the Hub and IR blasters and if what comes in the box will cover me.
Will the included Hub and IR blasters be able to cover all of this? Any potential problems?[/QUOTE
As far as the Hub, the two included mini blasters should cover the areas the Hub cannot cover. You can also buy a mini plug splitter to add more mini blasters if needed. Posts on page one contains a Q&A that covers most questions and which plug size to get..
Are updating the Touch to use it with the Hub which will give you the RF control like the Ultimate for about $99 or getting the Ultimate Home remote. I have the Ultimate and the also the Touch which I upgraded to work with the Hub. The Touch with the Hub is almost the same as the Ultimate minus a couple of areas.
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #2703 of 3743 Old 03-25-2015, 07:30 AM
mdavej's Avatar
Quoted: 2150 Post(s)
Liked: 949
The 360 will always be a problem. It needs a dedicated blaster right on top of the port or at least really close to it. Others should be ok.
mdavej is online now
post #2704 of 3743 Old 03-26-2015, 08:51 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
Got the Harmony set up and my AV installer told me I should return it for one much more configurable. So much of my house if now automated that I am considering it.
Samsung 75” 4k UHD 8550 | Oppo BDP-105D | Paradigm Studio 100's v5 (Mains Bi-amped) | Paradigm Studio CC-690 v5 (Center) | Paradigm ADP-590 v5 (Back) | SVS PB13-Ultra (x2) | Marantz AV-7702 mkII pre/pro | Emotiva XPA-2, XPA-3, XPA-5 | Harmony Ultimate Home Remote
DenonLover is offline
post #2705 of 3743 Old 03-27-2015, 08:37 AM
NickTheGreat's Avatar
Quoted: 388 Post(s)
Liked: 260
Such as???
I wish my Harmony did more, but I haven't found a good (consumer-level) option that doesn't look like it was inspired by something from the early 90's!
NickTheGreat is offline
post #2706 of 3743 Old 03-27-2015, 01:56 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Is it best buy running upgrade to ultimate promotion?
zoro is offline
post #2707 of 3743 Old 03-27-2015, 02:04 PM
Rambler358's Avatar
Quoted: 86 Post(s)
Liked: 25
And I'm sure it's not because he wants to sell you one and/or offer his programming services to you.
Gator99 and DenonLover like this.
Rambler358 is online now
post #2708 of 3743 Old 03-28-2015, 05:06 AM
dt744190's Avatar
Quoted: 18 Post(s)
Liked: 2
Originally Posted by NickTheGreat View Post
Such as???
Wait for Harmony Home Hub Extender that will expand ZigBee® and Z-Wave Plus™ compatibility. http://myharmony.com/products/detail/home-hub-extender/
Current listed as 130US at retailers.
Also with IFTTT Implementing that Logitech are testing out now.
https://ifttt.com/harmony
http://support.myharmony.com/en/harm...nce-with-ifttt
Sure it will do alot more than current Harmony remotes does.
dt744190 is offline
post #2709 of 3743 Old 03-28-2015, 03:51 PM
rotohead's Avatar
Quoted: 106 Post(s)
Liked: 56
Originally Posted by 413X3 View Post
My ultimate remote activity (directv) becomes unresponsive to every command sometimes, I can press buttons and the screen shows the buttons are pressed, but nothing happens. Not even the volume and it is tied to my receiver. No directv button works either. I have to change the activity to something else, then go back to my directv activity and everything works again for a bit. Resetting the remote and firmware does not fix it as this problem appears again days later at random. Anyone else?
And opening the harmony app on my apple laptop I get a prompt to update silverlight, I have the updated version already downloaded.
I thought my Ultimate was the problem but after troubleshooting this I've found that if you are on a Directv 'active' channel there are times when it is necessary to press 'exit' first before it will change channels, respond to a guide or list command. Something to try before making any changes to your remote configuration.
rotohead is offline
post #2710 of 3743 Old 03-28-2015, 03:51 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
Such as???
My installer suggested the Complete Control but also mentioned the URC, General Pro, Crestron, Phillips, RTI, and UEI. In a perfect world their would be a local member who could give me a hand over a beer and some tequila shots.
post #2711 of 3743 Old 03-28-2015, 04:14 PM
mdavej's Avatar
Liked: 949
You need to decide if you want to maintain the system yourself or pay someone else to do it. The above systems will be thousands in hardware and thousands more for programming services. Then a couple hundred every time you need to make a change. Nothing wrong with that approach, but just want to make you aware it won't be anywhere near as cheap as Harmony.
BTW, he's working with some old information. Philips left the pro remote business a few years ago. And UEI no longer has a pro line either (although they do make my favorite remotes of all time - JP1 and Xsight). I've never heard of General Pro, if that's really a thing.
post #2712 of 3743 Old 03-28-2015, 08:12 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
I would likely want to maintain the Harmony myself but if I moved to a complete control I would likely want them to do it. I am doing a bunch of home automation now so it would be cool to have it all off of the remote. The sun shades behind our woven wood blinds in the living are set up for me to control as are the big ass fans with haiku, the garage door opener, the front door and some lighting (and soon to add backyard lighting and sprinklers) just not sure I am ready for the steep cost to have installed. I think I need to really think this one over and see if I can live with the harmony.
post #2713 of 3743 Old 03-29-2015, 05:11 AM
Gator99's Avatar
Quoted: 72 Post(s)
Have you ever thought about iRule or roomie remote?
Sent from my Nexus 5 using Tapatalk
Jeff
Gator99 is offline
post #2714 of 3743 Old 03-29-2015, 08:52 AM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
I have never seen or heard of either of those two apps but they both look like they were quite well. I will check them out, thank you.
post #2715 of 3743 Old 03-29-2015, 09:06 AM
Gator99's Avatar
Quoted: 72 Post(s)
They have pros and con's, I use iRule, the two biggest cons:
You have to use tablet or phone, no physical remote
Learning curve, can be interesting depends on your skill set their forums are good and we have a thread here as well.
As info I use irule and Harmony, like them both, but I tinker with iRule all the time, having feedback is a big reason why.
DenonLover likes this.
Jeff
Gator99 is offline
post #2716 of 3743 Old 03-29-2015, 08:42 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
I am holding off right now to see what Apple is going to do with the iHome. They seem to be pretty good at networking.
post #2717 of 3743 Old 03-30-2015, 06:54 AM
RVD26's Avatar
Quoted: 55 Post(s)
Just posting to say I love my Harmony Ultimate
Logitech gave me this remote as a replace for my Harmony One, which had the swollen battery issue.
The only issue I get is when I clean the screen and it goes a little wonky from all the commands being pressed during the cleaning.
A reboot always fixes the issue though.
49Merc likes this.
RVD26 is offline
post #2718 of 3743 Old 03-30-2015, 07:36 AM
rehaz1's Avatar
Quoted: 56 Post(s)
Liked: 30
There is an option to lock the screen on the Ultimate so you can clean it. Select the Menu Icon on the LCD screen, select Setting select Remote, select Remote Lock, when you are done cleaning press and hold the Exit button until the screen returns to normal.
RVD26 likes this.
rehaz1 is offline
post #2719 of 3743 Old 03-30-2015, 08:45 AM
Quoted: 388 Post(s)
Liked: 260
I bet he did.
post #2720 of 3743 Old 03-30-2015, 10:18 AM
mdavej's Avatar
Liked: 949
You could probably pull most of that off with Mi Casa Verde (I think they changed their name recently) plus Harmony Home and a few custom interfaces. But I agree iRule would be a better fit and give you feedback and far more customization.
I found this, which I thought was pretty funny. If you go to remote central (below) and scroll down to the Professional remote forum, you get the exact same list he told you, including "General Pro" which isn't even a brand but the name of the forum.
http://www.remotecentral.com/cgi-bin/mboard/forums.cgi
Do give your scope some more thought. I've never needed to remotely control my sprinkler system, for example.
post #2721 of 3743 Old 03-30-2015, 03:52 PM
mconigs78's Avatar
Anyone have the white remote? If so does it get dirty fast?
mconigs78 is offline
post #2722 of 3743 Old 03-31-2015, 05:37 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
White remote
no I haven't had a problem other than the leather furniture and the color rubbing off on bottom of it when sitting on the furniture!!
Spoiler!
azz7686 is offline
post #2723 of 3743 Old 03-31-2015, 09:16 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
What is the quickest way to learn how to set up your remote? Did it take you a long time do and did it come pretty easy for you. I guess I just need to dive in and start learning how t set this up and use it.
post #2724 of 3743 Old 03-31-2015, 09:19 PM
Rambler358's Avatar
Quoted: 86 Post(s)
Liked: 25
You just need to note what inputs your devices are connected to, and you should be all set. Jump in, the water's nice!
post #2725 of 3743 Old 04-02-2015, 11:54 AM
Topher's Avatar
How's the latest firmware working? Is there still the buffering issue?
Topher is offline
post #2726 of 3743 Old 04-05-2015, 10:21 AM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
Wow, install was so easy and I have no idea why I was so afraid to invest all of my day to doing this when it only took about 30 mins. Has anyone with remote access to their garage (via internet gateway 828LM) tried to use their remote to open their garage? I did see an option for Lift Master under Home Automation so I am not sure if I am doing something wrong or if my model was not added yet? I added this question to the Lift Master myQ community too in case this is a Lift Master issue and not a Harmony issue (see below).
"First off I would like to say I can not imagine this installation of my 828LM to my Lift Master 8550 any easier. It immediately created the link and gave me access to open and closing my garage door from my iPhone. Has anyone tried to Sync this to their Harmony Ultimate Home Touch so they can remotely open their garage from their remote. Should be pretty simple but the software does not see recognize the remote even though Lift Master is one of the options. "
post #2727 of 3743 Old 04-06-2015, 06:10 AM
PeterLewis's Avatar
Quoted: 136 Post(s)
Liked: 70
Need a little help,
I have a harmony ultimate one that does not want to power up my Sony STR-ZA3000ES avr during activities put it will power up when I just select the avr by itself and hit the power on button.
I have tried many delays and power options via the webpage software to no avail.
Sony OLED XBR-65A1E (Pre-Ordered)| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is online now
post #2728 of 3743 Old 04-06-2015, 11:08 AM
Topher's Avatar
Maybe a little late, but if the 360 is hooked up to your network, the Harmony will control it by IP so you don't have to rely on IR blasters.
Topher is offline
post #2729 of 3743 Old 04-07-2015, 03:46 PM
mikeo24's Avatar
My Harmony Ultimate Remote does not keep its charge for more then 10mins and its dead. Anyone else having issues with their remotes battery life? I'm really disappointed and starting to doubt my purchase. Remote is updated to the latest firmware.
mikeo24 is offline
post #2730 of 3743 Old 04-07-2015, 04:34 PM
bweissman's Avatar
Quoted: 225 Post(s)
Liked: 88
It's dead, Jim. My 1-year-old Ultimate's battery lasts for days. Don't shoot the messenger. Contact Logitech and ask them to replace it.
bweissman is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
