Harmony Ultimate, Smart Control and Hub - Page 93 - AVS | Home Theater Discussions And Reviews
 46Likes
post #2761 of 2764 Old Today, 12:28 PM
rehaz1's Avatar
Quoted: 27 Post(s)
Check to see if one of the buttons is stuck. Try massaging each of the buttons
rehaz1 is offline
post #2762 of 2764 Old Today, 12:35 PM
rotohead's Avatar
Quoted: 63 Post(s)
Liked: 38
Originally Posted by markmathers View Post
Hello. I'm experiencing a problem with my remote. Everything seems to work ok but it's as if the remote is constantly trying to start an activity, as I'm seeing the blue dotted lines move across the top of the screen. I try starting an activity, shutting it off, I even tried syncing the remote and nothing gets it to stop. Also, as a result, the backlight is constantly on as well. The only thing I can think will solve the problem is to let the remote battery die and then charge it again. Anyone have any ideas? Thanks
Have you tried to press/hold 'record' and 'menu' buttons at the same time? I think that is the reboot method. I'm not at home right now and without the remote in my hand I'm going from memory (and at my age that is dicey). Hope this helps.
rotohead is offline
post #2763 of 2764 Old Today, 12:53 PM
azz7686's Avatar
Quoted: 35 Post(s)
It is off button and menu button for 20 seconds.
2-RTi-10's 1-CSi5 2-TSi400 6-r150's 1-Velodyne DPS-12
Yamaha RX-A3030 and Emotiva XPA-200
Samsung UN65F7100
azz7686 is offline
post #2764 of 2764 Unread Today, 05:06 PM
49Merc's Avatar
Quoted: 59 Post(s)
Resync it. If that does not work I would reprogram. Radical but maybe necessary. Good luck.
Sony HDTV KDL-46HX750, Denon AVR 1912, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Rcvr, Panasonic Blu-ray DMP-BD65, Toshiba HD DVD A20, Infinity Alpha Speakers 50's, 20's, 10's, 37c, Valodyne VRP-1000 Sub, Panamax M4300-PM, Harmony Ultimate One Remote, Monoprice AV Cables
49Merc is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
