Harmony Ultimate, Smart Control and Hub - Page 95 - AVS | Home Theater Discussions And Reviews
 49Likes
post #2821 of 2825 Old 05-30-2015, 10:55 PM - Thread Starter
Keith Mickunas's Avatar
Quoted: 93 Post(s)
Liked: 78
Originally Posted by bodean View Post
Remote and Hub Assignments?
https://support.myharmony.com/en/con...not-from-the-h...
When would you select REMOTE over HUB for your devices?
Should all devices be set to remote and not hub?
My devices are:
Xbox one
Dish DVR
Sony TV
Amazon Fire TV
Bose AV Receiver
They are all in line of site of me on the couch (Not in a cabinet).
I noticed my Ultimate is having issues controlling the volume on my AV Receiver when the device is set to HUB, but setting to remote works fine.
If you set it to hub and the hub doesn't have a good line-of-sight then it's not going to work well. All you are doing is specifying which device is actually sending the IR signal. Those of us that have our equipment in a cabinet or closet need the hub. In those cases it is optimal to use the hub for all the source devices, and the remote only for the display. The hub also has the emitters which can be attached and placed so that they can send the IR to your devices.
Keith Mickunas is offline
post #2822 of 2825 Old Today, 05:45 AM
cgott42's Avatar
Quoted: 116 Post(s)
With the new news re: the Harmony Home Hub - will the model 915-000224 now work with the home hub? or smart hub?
cgott42 is offline
post #2823 of 2825 Old Today, 07:23 AM
dt744190's Avatar
Liked: 2
I suggest peoples DO NOT UPDATE to latest 4.5.66 and wait until Logitech fixes the device power settings bugs.
I had this problem already with 4.3 and 4.5.66 makes it even worser.
http://forums.logitech.com/t5/Harmon...e/td-p/1409443
dt744190 is online now
post #2824 of 2825 Unread Today, 07:53 PM
David Susilo's Avatar
Quoted: 399 Post(s)
Liked: 454
I finally bought an Ultimate for my bedroom, but for my DVR, the numbers are not shown on the activity page (it shows the grid with no number). However, under "Devices", I can find the numeric pads and use them.
Any idea what
on how to get those numbers back?
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED, QAV, AUVI & DownUnder Audio Magazine
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2825 of 2825 Unread Today, 10:21 PM
dt744190's Avatar
Liked: 2
Any idea what
U can add them manually under Buttons and choose u device to add commands.But I just notice, with 4.5.66, they have also changed only can add 1 device commands and not as before commands for multi devices on same screen. What a stupid change.
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
