Control Onkyo TX-NR414 with 3rd party remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-18-2013, 12:16 AM - Thread Starter
chuckjatk's Avatar
Anyone have a suggestion on a universal remote that can control the Onkyo TX-NR414? I've been reading that the codes aren't available.
Anyone had any luck with a learning remote?
chuckjatk is offline
post #2 of 3 Old 04-19-2013, 07:38 AM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 987
Where did you read this? Onkyo has used the same codes for over 10 years. It would be strange for them to change now, especially with this particular low end model. What universal remote are you using that isn't working?
In any case, the codes are in the harmony database. And Onkyo codes are in most every other universal remote.
mdavej is online now
post #3 of 3 Old 04-19-2013, 10:51 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
mdavej,
This thread at RemoteCentral (and another one by the same knowledgeable poster) says he wasn't able to get the NR414 to accept normal Onkyo signals. Then in this thread, started probably by the same poster, Onkyo support says the codes are different. On the other hand, urcsupport.com says Audio 1805 "should" work with the NR 414, and UEI should know because they provide the IR data for Onkyo remotes.
We have seen that the HTX series of Onkyo receivers, and I believe also some Integras, use a different remote ID, which use the same device (210) and function numbers but different subdevice numbers. See this thread and the thread linked in it. I think that the user of these components could just change to ID1, but perhaps the HTX series doesn't allow that. The NR414 does allow setting the remote ID.
I don't know whether the standard codes will work or not. If they do, then lots of remotes will work. Of course a JP1 remote with cable will work either way, and I suppose that a Harmony should also work.
3FingeredGlove is offline
Reply Remote Control Area
Onkyo Tx Nr414
