RF Remote(?), need recommendations please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-13-2013, 11:04 PM - Thread Starter
Late Nighter's Avatar
Hey everyone -
I have a 10 yr old Yamaha receiver, and 4 outdoor speakers. I am going to install the receiver somewhere tucked away in the basement near and the wall and drill through and run the speakers, but I want to be able to use a remote that can control it from anyplace in doors or outdoors since the receiver will be so remote. The controlling would be basic (switch input device & volume control primarily) so I dont need anything too elaborate.
Can anyone refer me to a good match for this basic need, or refer me to a thread here on AVS of similar need?
thanks for all your considerations
Late Nighter is offline
post #2 of 8 Old 05-14-2013, 10:54 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
You could try using a RF remote solution or if you have a smartphone/tablet then you could use IP control over WiFi. In your example I'd lean toward the smartphone route since you would want to control it from multiple locations and would probably have the phone with you. With the remote you would need two remote or carry it between locations.
bryansj is online now
post #3 of 8 Old 05-14-2013, 09:43 PM
Adidas4275's Avatar
i love my Logitch 890 and it works well, I would also recommend using a smart phone with a global cache IP/IR unit
Adidas4275 is offline
post #4 of 8 Old 05-14-2013, 11:52 PM - Thread Starter
Hey thanks so much for your replies, both of you.
Adidas4275, that remote is listed at $349 which would kill my budget and likely overkill for what I need. Are there cheaper more simplified options you could advise of?
And you both mentioned WiFi - can you provide specific products that could support this?
I like the idea, but am concerned with wife not being able to use it if I am not there (hence just having a remote to power it on from the walkout area).
thanks again for any further thoughts...
post #5 of 8 Old 05-15-2013, 06:18 AM
bryansj's Avatar
Liked: 560
Do you have a smartphone? If not then the WiFi route would have to include a smartphone/iPod Touch/tablet in the budget.
Have a look at the iRule thread for a general idea. There are other companies that have IR to WiFi solutions besides iRule, but it has the most info posted here.
post #6 of 8 Old 05-15-2013, 06:45 AM - Thread Starter
bryansj-
Yes, I have an iPhone 5 smartphone for wiFi. Thanks for the tip on iRule, I will seek out that thread.
post #7 of 8 Old 05-15-2013, 07:57 AM
bryansj's Avatar
Liked: 560
You'll need a device like this http://www.globalcache.com/products/itach/ that connects your iPhone via WiFi to send IP signals that are converted to IR.
If you can connect to Ethernet then you just need the IP2IR, if not then you would need the WF2IR.
post #8 of 8 Old 05-15-2013, 11:57 PM - Thread Starter
Ok will check that out today, thanks again.
Reply Remote Control Area
Logitech Harmony 890 Advanced Universal Remote Control , Irule
