Philips Prestigo SRU8015 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-18-2013, 11:12 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Does anyone own this remote? I just got one for a decent price so I can get at least 4 remote onto just a single one, I just don't hear this one talked about much here.
SubaruB4 is offline
post #2 of 8 Old 05-19-2013, 06:23 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
I do not own the SRU8015, but I do own the SRU 9600. To be honest it merely sits on the cabinet now, as it cannot compete with the Harmony remotes in use.
It is a decent remote. What I like is that it does have "Activities", and it is fairly straightforward to set up. I happen to like the heavy weight of it, and the screen is cool.
But, using the "scroll wheel" is not intuitive, I couldn't get the family used to the moves of "Jog" then clicking through.
What I do not like about it is that I cannot "program" it in any way. It does have learning capability, but unlike a Harmony, or even a JP1 style universal remote, I cannot enter custom commands, or EFC commands.
So, it's not a bad remote, it does have its "pluses", but overall it cannot compete with other remotes. If you got for a great price (as I did mine!), try it out and see how you like it.
SubaruB4 likes this.
Sometimes I have to remind myself that I bought all this "stuff" to enjoy it!
bizwiz41 is offline
post #3 of 8 Old 05-19-2013, 06:32 AM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Yeah I got it for $24 can't complain much on that.. I really wanted this URC remote but gotta save up a bit more for that one wink.gif
SubaruB4 is offline
post #4 of 8 Old 05-19-2013, 01:35 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Here is a stupid question.. I have a projector I brought used without a remote.. but a remote is $35 rolleyes.gif I assume to get the projector to work I'm going to need to have to get the remote for the projector to learn it?
Friken $35 bucks....
Well I found one for $27 but still...
SubaruB4 is offline
post #5 of 8 Old 05-19-2013, 07:07 PM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
Most universal remotes have built-in codes for most devices so learning isn't necessary. Have you tried the built-in codes? In any case you can buy a cheaper universal that has the codes if you need to teach the philips.
mdavej is offline
post #6 of 8 Old 05-19-2013, 08:19 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
I doubt any of them are going to have codes for a recent infocus projector.. I just went ahead and got the remote, I thought logitech would have the code.. and nope.. so much for a huge database.
SubaruB4 is offline
post #7 of 8 Old 05-20-2013, 06:09 AM
mdavej's Avatar
Liked: 992
Most models within a brand have the same codes. So an older model from the Logitech database likely would have worked. The UEI database has 8 Infocus codes (mostly NEC1), so a $3 JP1 also would have worked. I'm just saying we could have solved your problem for less money.
mdavej is offline
post #8 of 8 Old 05-20-2013, 09:41 AM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Oh well.. if I find that the codes works then I can sell the remote if not I will keep it.
SubaruB4 is offline
Reply Remote Control Area
Philips Prestigo Sru9600 Universal Remote Control
