Ugh... I want to hit my head on a wall. This is the online chat support I received from Sony regarding Hex Codes. NSX-46GT1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-29-2013, 08:55 PM - Thread Starter
BrittonYoder's Avatar
Liked: 36
8:56 PM Connecting...
8:56 PM Connected. A support representative will be with you shortly.
9:06 PM Support session established with Michael - (C5BG).
9:06 PM Michael - (C5BG):
Hi . Welcome to Sony Online Support. My name is Michael.
9:08 PM Michael - (C5BG):
I understand that you want help to discrete IR Hex codes for On, Off, HDMI1, Component, am I right?
9:10 PM Customer:
yes
9:10 PM Customer:
sorry
9:10 PM Customer:
I walked away for a second
9:10 PM Customer:
That would be amazing!
9:10 PM Michael - (C5BG):
It's okay.
I will be glad to help you with.
9:11 PM Customer:
Great!
9:11 PM Michael - (C5BG):
Kindly allow me few moment to collect the information for you.
9:11 PM Customer:
not a problem
9:19 PM Michael - (C5BG):
Sorry for making you wait long.
9:19 PM Customer:
no worries
I appreciate your patience.
9:19 PM Customer:
I am just thrilled to have the help
9:19 PM Customer:
I have looked online for hours
9:20 PM Michael - (C5BG):
Connect an IR Blaster to the unit and place it properly on the cable/satellite box
9:21 PM Michael - (C5BG):
Press Fn + 1 and select.
9:21 PM Connecting...
9:21 PM Connected. A support representative will be with you shortly.
Select [Add device manually], then follow the on-screen instructions.
9:21 PM Support session established with Michael - (C5BG).
9:21 PM Customer:
can it be a regular IR emitter
9:22 PM Michael - (C5BG):
Yes.
9:22 PM Customer:
and just to verify we are looking for the codes to control the tv
9:22 PM Customer:
not the cable box
Okay.
9:23 PM Connecting...
9:23 PM Connected. A support representative will be with you shortly.
9:23 PM Customer:
ok one second let me get it ready
9:23 PM Michael - (C5BG):
Sorry for the wrong information.
9:23 PM Support session established with Michael - (C5BG).
9:25 PM Michael - (C5BG):
It requires IR Blaster to to control the TV.
9:25 PM Customer:
OK back, I had to unmount the TV and move it to the equipment room where the sat box was located
9:26 PM Customer:
I hit fn+1
9:26 PM Michael - (C5BG):
Okay.
9:27 PM Customer:
I am a little confused, I have a control system that I need to have control the TV power and inputs, I am not looking to have the TV control anything
9:27 PM Connecting...
9:27 PM Connected. A support representative will be with you shortly.
9:27 PM Customer:
through the blaster
9:27 PM Connection lost. Attempting reconnection...
9:28 PM Support session established with Michael - (C5BG).
9:28 PM Customer:
Just need the Hex code like....
9:28 PM Customer:
POWER ON,0000 0067 0000 000D 0060 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0450
POWER OFF,0000 0067 0000 000D 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0438
9:33 PM Customer:
are you still there?
9:33 PM Michael - (C5BG):
Unfortunately you are not able to control other devices with the Internet remote.
9:34 PM Michael - (C5BG):
Sorry I was collecting the information for you.
For more information kindly view the below link which I will sent you.
9:34 PM Michael - (C5BG) has sent a link: http://helpguide.sony.net/internettv/nsx-gt1/v2/us1/05/05-03_1.html?search=code#h3-1
9:35 PM Customer:
thats not really what Im looking for
9:35 PM Michael - (C5BG):
Please let me know if you are able to view the page.
9:35 PM Customer:
I have a universal remote
9:35 PM Customer:
that controls not only this TV
9:35 PM Customer:
but also 15 other components
9:35 PM Customer:
with all the other tvs in the house
9:35 PM Customer:
you hit watch tv
9:36 PM Customer:
and the remote turns on all the required equipment
9:36 PM Customer:
turns on the tv and selects the correct input
9:36 PM Customer:
there are databases that a published for all IR codes for every TV but this one
9:37 PM Customer:
So I need the hex codes or method of obtaining the hex codes
9:37 PM Customer:
that will turn on and off the tc
9:37 PM Customer:
tv*
9:37 PM Customer:
and select the input
9:37 PM Customer:
discretely
9:37 PM Michael - (C5BG):
Is it Sony Universal remote?
9:37 PM Customer:
on this TV only, no other devic
9:37 PM Customer:
no, its a control system that costs more than the TV.
9:38 PM Customer:
for a smart home
9:38 PM Customer:
but all universal remotes use hex code
9:38 PM Customer:
and I am just looking for the codes for this TV
9:39 PM Michael - (C5BG):
we are unable to provide support for remote controls designed by other manufacturers.
Manufacturers may assign different code numbers in their universal remote controls to identify the Infrared (IR) signal of a Sony product.
Thus, the code number used for operating a Sony product in one remote control may be different from that used by another.
9:40 PM Michael - (C5BG):
For information about programming a third-party remote control, contact the manufacturer of the remote control.
9:40 PM Customer:
well
9:41 PM Customer:
its not like a code
9:41 PM Customer:
A5
9:41 PM Customer:
or 55
9:41 PM Customer:
in the back of a manual
9:41 PM Customer:
its hex which is designated by the television manufacturer
9:41 PM Customer:
9:41 PM Customer:
that is the code for on
9:41 PM Customer:
no matter what brand
9:42 PM Customer:
of remote
9:42 PM Customer:
you can use that
9:42 PM Customer:
and it will turn any sony tv on or off
9:42 PM Customer:
sony made that
9:42 PM Customer:
there exists similar codes to control the inputs
9:43 PM Customer:
that is what I am looking for
9:43 PM Customer:
sony developed them specific to this tv
9:43 PM Michael - (C5BG):
Unfortunately we do not have information about this.
9:44 PM Customer:
is there a level 2 tech support
9:45 PM Michael - (C5BG):
Kindly try to contact the third party remote control service support team.
9:45 PM Customer:
they said sony is the only one with this information
9:46 PM Michael - (C5BG):
I would like to assist you, but Sony believes that such concerns are best conducted with our dedicated customer service team. Let me give you their contact information. Kindly contact them at : 1-800-222-7669
9:46 PM Customer:
Is there a level 2 tech support
9:46 PM Customer:
its not customer service
Sorry we do not have.
9:46 PM Customer:
so who do people contact when your dept doesnt know the answer
9:47 PM Customer:
because customer service doesnt know anything technical
9:47 PM Customer:
they are there to solve problems related to policy
9:47 PM Customer:
not technical matters
9:49 PM Michael - (C5BG):
They are our next level technical support team.
Please contact them for further assistance.
9:49 PM Customer:
ok do you know what their hours are
9:50 PM Michael - (C5BG):
24 hours a day, 7 days a week
9:51 PM Customer:
Ok thanks
9:51 PM Michael - (C5BG):
Thank you for contacting Sony On line Support. Have a great day.
9:51 PM Michael - (C5BG) would like you to complete a brief Customer Survey. Open Customer Survey
9:51 PM Michael - (C5BG) has ended the session.
Check out my whole house build HERE
BrittonYoder is offline
post #2 of 11 Old 05-29-2013, 10:12 PM
jeepin01's Avatar
I had an almost identical conversation troubleshooting a Blu Ray player issue. I was so upset with the service I called customer service the next day. I tried explaining my issue was no longer the player that wasn't working but the total lack of technical support. They clearly never figured out why I was upset. I asked to talk to someone that actually understood the product and they referred me to the same line I called them to complain about. Banged my head on the wall, gave up, and cut my losses after that. It was clear another hour on the phone wouldn't accomplish anything.
jeepin01 is offline
post #3 of 11 Old 05-30-2013, 08:51 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
I feel your pain. The folks manning the phones and online chat unfortunately have no technical expertise and no power or mechanism to provide any meaningful technical information besides what's scripted.
What model tv? Maybe I can find some codes you can try. Have you seen THIS? Sony often uses the same codes across many models. But I have seen reports that some newer sony's lack discretes altogether.
mdavej is online now
post #4 of 11 Old 05-30-2013, 09:15 AM - Thread Starter
Liked: 36
I'm glad to hear I'm not the only one frustrated by their technical support. I haven't seen that link, I will check it out and try this evening. The TV is the NSX-46GT1, the Sony Google TV. I was able to get discrete on/off to work and then next input. I had to build a bunch of variables to get the inputs to switch properly. Obviously, this isn't ideal.
post #5 of 11 Old 05-30-2013, 09:16 AM - Thread Starter
Liked: 36
Thanks for the feedback, it saved me an hour on the phone with customer service. What was your issue with the BDP?
post #6 of 11 Old 05-30-2013, 09:23 AM
mdavej's Avatar
Liked: 940
Here are the known codes for that model that you can use to find some candidate discretes in the files I linked. If you had a JP1 remote, you could do a brute force code search. Do you have such a remote, perhaps an old cable tv, radio shack or one-for-all?
Code:
Command      Protocol        Device  OBC
Audio   Sony12  1       23
Blue    Sony15  151     36
ChannelDown     Sony12  1       17
ChannelUp       Sony12  1       16
CloseCaption    Sony15  151     40
DirectionDown   Sony15  151     80
DirectionLeft   Sony15  151     77
DirectionRight  Sony15  151     78
DirectionUp     Sony15  151     79
Exit    Sony12  1       99
FastForward     Sony15  151     28
Green   Sony15  151     38
GTVBack Sony15  151     35
GTVHome Sony12  1       96
GTVMenu Sony15  151     54
GTVPiP  Sony12  1       100
Guide(STB/TV)   Sony12  1       14
Info(STB/TV)    Sony12  1       58
Input   Sony12  1       37
LiveTV  Sony15  151     125
Mute    Sony12  1       20
Pause   Sony15  151     25
Play    Sony15  151     26
PowerOff        Sony12  1       47
PowerOn Sony12  1       46
PowerToggle     Sony12  1       21
Record  Sony15  151     32
Red     Sony15  151     37
Rewind  Sony15  151     27
Select/Ok       Sony15  151     74
SkipBackward    Sony15  151     60
SkipForward     Sony15  151     61
Stop    Sony15  151     24
VolumeDown      Sony12  1       19
VolumeUp        Sony12  1       18
Yellow  Sony15  151     39
.       Sony15  151     29
0       Sony12  1       9
1       Sony12  1       0
2       Sony12  1       1
3       Sony12  1       2
4       Sony12  1       3
5       Sony12  1       4
6       Sony12  1       5
7       Sony12  1       6
8       Sony12  1       7
9       Sony12  1       8
post #7 of 11 Old 05-31-2013, 06:17 AM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I don't know if this will help you out but I had a similar situation last week. I have a URC MX-450 in my bedroom and I tried all the codes for my new Sony TV but none of them would do discreet input commands. I was just about to give up when I remembered that I have a Harmony 890 in my main theater room. I added the Sony TV to the Harmony and used that to teach the discreet commands to the URC. If you have a Harmony lying around or know someone who has one you could borrow for an hour it may be worth a try.
Dropkick Murphy is offline
post #8 of 11 Old 06-04-2013, 11:21 PM
themoderntheatre's Avatar
Here was mine. Trying to figure out if the Sony 2800ES can convert HDMI audio to the zone 2 speaker terminals... I hear Denon can do this and the Sony is rumored to be able to, but couldn't confirm online.
11:55 PM Connecting...
11:55 PM Connected. A support representative will be with you shortly.
11:55 PM Support session established with Tyson - (C5DK).
11:55 PM Tyson - (C5DK):
Hi . Welcome to Sony Online Support. My name is Tyson.
11:56 PM Customer:
I have a question about zone 2 on the Sony 2800es
11:56 PM Tyson - (C5DK):
Please go ahead.
11:57 PM Customer:
Will it convert digital sources such as the HDMI inputs to analog for zone 2?
11:57 PM Customer:
As in I plug an HDMI in from a source and I want it to play sound through the zone 2 speaker terminals
11:59 PM Tyson - (C5DK):
I understand that you own a Multi Channel AV Receiver , model#STRDA2800ES and you want to know if you are able to play digital music on it through HDMI. Is that right?
12:00 AM Customer:
no
12:00 AM Customer:
I want to know if the Sony will convert digital audio from an HDMI output and convert it to analog to play through the speaker terminals in zone 2
12:01 AM Tyson - (C5DK):
Alright.
12:02 AM Tyson - (C5DK):
This receiver incorporates Dolby Digital and Pro Logic Surround and the DTS Digital Surround
System.
12:05 AM Customer:
What's your point?
12:05 AM Customer:
That statement has nothing to do with my question
12:09 AM Tyson - (C5DK):
Please wait while I provide the answer to your question.
12:10 AM Connection lost. Attempting reconnection...
12:13 AM Support session established with Tyson - (C5DK).
12:13 AM Tyson - (C5DK):
I am sorry for the inturruption.
It appears we may have been disconnected. Please respond so that I can confirm our connection.
12:14 AM Customer:
I'm here
12:14 AM Tyson - (C5DK):
Alright.
12:15 AM Tyson - (C5DK):
You can play Digital sound on Zone 2.
Do you have the manual of the unit?
12:16 AM Customer:
Yes
12:16 AM Customer:
Digital sound from the HDMI inputs?
12:17 AM Customer:
Or only optical/coax?
12:17 AM Tyson - (C5DK):
HDMI is also playable. Just refer to page #75 on the manual.
12:17 AM Customer:
hdmi through zone 2
12:18 AM Tyson - (C5DK):
Yeah.
A detailed instruction is there on the topic under "Setting the Zone2 HDMI output".
12:19 AM Customer:
Yes but that's video from the HDMI output not the zone 2 audio
12:20 AM Customer:
I'll just figure this out on my own
Ryan Siu
Founder, Owner
The Modern Theatre LLC
themoderntheatre is offline
post #9 of 11 Old 06-06-2013, 04:26 PM
Quoted: 71 Post(s)
Liked: 89
LOL, that's a good one...
If I'm reading this correctly, you can only output analog through the Zone 2 Audio Out, but if you use the Zone 2 HDMI out it will play HDMI sources (weird).
My Yamaha will play HDMI sources in Zone 2 if the receiver is in "PARTY MODE" (both zones playing the same source simultaneously). You could try searching the manual to see if your Sony has a similar feature.
post #10 of 11 Old 06-09-2013, 11:34 PM
drboyd's Avatar
If you ever had a Sony Dash, or know anyone who has had a Sony Dash, you'll understand why I say that I wouldn't give my worst enemy's dog a Sony rubber bone.
drboyd is offline
post #11 of 11 Old 06-16-2013, 03:56 PM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
I once tried to get the rs232 control codes for a Sony receiver (pre purchase). I even went past support and corresponded with the US executive staff.
After that experience I don't buy Sony products. ever.
BizarroTerl is offline
Reply Remote Control Area
Sony 46 Inch Led Hdtv Nsx 46gt1
