Noob IR Solution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-08-2013, 07:54 PM - Thread Starter
soxinsav's Avatar
Hi all, I'm in a little over my head on something and hoping you can help me out.
I currently have an Onkyo NR709 connected happily to:
TV - Samsung PN64D550C1FXZA
Blu Ray - Panny DMP - BDT220
Cable Box - Cox Communications Explorer 8240 HDC
Wii
Delphi Myfi XM Radio unit (first gen)
We are doing some home renovations and my wife asked what the possibilities were of running an IR remote extender and placing the 709, our cable box, blu ray, and Wii in our laundry room. I'm researching the remote interactive function on the 709 and I just don't understand it. Can I connect a remote extender such as this one from Monoprice:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=7973&seq=1&format=2
connect that to the 709 and with a little configuration of the devices have them be operated through the RI function of the 709? Does it depend on the device if that is an option or do I need an IR connector to every device I have in the laundry room?
Any info on how to set up a system like this is helpful.
Thanks in advance for your help.
Soxinsav
soxinsav is offline
post #2 of 4 Old 06-10-2013, 01:34 AM
Bryan J's Avatar
Hi
Yes an IR extender would get round this for you.
The mono price kit is wireless so can be prone to interference issues from Wi-fi etc.
Also it seems as though it was designed to control one piece of kit so you would need to enquire as to whether it can do more.
Personally I would always opt for a hardwired solution rather than a wireless as they are less prone to issues.
Plus they tend to be more discrete.
We do have a wide range of solutions such as the kit below:-
http://www.keene.co.uk/electronic/keene-electronics/keene-ir-distribution-extender-kit-%28fascia-rcvr%29/irbkitf.html
You can extend the receiver over cat5/network up to around 30meters using one of these adaptors
http://www.keene.co.uk/electronic/unbranded/3.5mm-stereo-jack-plug-/-socket-to-cat-adaptors/ka175.html
Hope this helps.
Bryan J is offline
post #3 of 4 Old 06-10-2013, 10:49 AM
raczcar's Avatar
If you can run a cat5 you can extend a emitter with that also to be more reliable.
raczcar is offline
post #4 of 4 Old 06-11-2013, 01:24 AM
Bryan J's Avatar
Yes you can extend the emitter to approx 35-40 meters
Bryan J is offline
Reply Remote Control Area
Panasonic 3d Blu Ray Player Dmp Bdt220
