Direct tv HD DVR34 Gennie ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 06-27-2013, 01:31 PM - Thread Starter
sportman1's Avatar
I hope you can help me I got a Direct tv HD DVR Gennie am not sure I was given the right remote could you post the remote which goes with the Direct tv HD DVR Gennie do theses go with the DIRECTV TiVo Remote for THR22 or HR2X DVRs DIRECTV Universal Remote RC71 Direct tv HD DVR Gennie
sportman1 is offline
post #2 of 38 Old 06-27-2013, 02:58 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
No, the hr34 oem remote model is the rc65rx. But any of the following Rf directv remotes would work: rc32rb, rc34, rc64r, rc64rb, rc65r, rc65rx, and rc65rbx.
The THR22 tivo remote is not the RC71, this is the THr22 remote:
http://www.wkblog.com/tivo/2012/02/directv-tivo-thr22-extra-remotes/
where the rc71 is this remote, second photo down:
http://forums.solidsignal.com/showthread.php/3893-WHITE-PAPER-Using-your-DIRECTV-remote-with-your-TV
The rc71 is the oem remote for HR44 genie, only works the hr34 in IR mode, but not RF mode.
Edmund is offline
post #3 of 38 Old 06-27-2013, 03:25 PM - Thread Starter
sportman1's Avatar
Edmund which works better with the DIRECTV dvrhd34 gennie theDIRECTV TiVo Remote for THR22 or HR2X DVRs DIRECTV Universal Remote RC71
post #4 of 38 Old 06-27-2013, 03:33 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Stop putting the THR22 tivo in the same sentence as the rc71 remote, they have nothing to do with each other.
The best remotes for hr34 is the rc65rx or rc65rbx.
The thr22 tivo peanut remote would control the hr34 in both IR and RF modes, but the tv codes the tivo peanut uses are only found in the thr22 tivo receivers on-screen menu. Where the tv code in the hr34 menu are useless. They are only good on the white directv remotes like ones listed in my first post.
Edmund is offline
post #5 of 38 Old 06-27-2013, 03:51 PM - Thread Starter
sportman1's Avatar
Edmund The thr22 tivo peanut remote can it be programed the buttons for tv and record and the New Gennie Remote ? to I do not like the record buttons on remotes for hr34 is the rc65rx or rc65rbx.the
post #6 of 38 Old 06-27-2013, 04:27 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
To program the THr22 remote to the hr34 in IR mode:
1. press and hold Tivo & Pause until light remains on, release
2. press #1 key, or whichever between 1-8 that matches the receivers IR address.
If the HR34 is in RF mode, then to get the tivo peanut to control it:
1. press and hold Tivo & Stop until the light remains on, release
2. enter the last 6 digits of the Receiver ID#(RID), found on a sticker in the access card compartment
As I wrote, the tivo peanut can control a tv, but the tv codes are only found in the menu of the thr22 receiver, which I do not have access to, to help program the tivo remote to your brand of tv.
Edmund is offline
post #7 of 38 Old 06-27-2013, 04:34 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Reading your other thread at sat guys, in it you say you have a standard tivo remote, which WILL NOT control the HR34, only true THR22 peanut will. The thr22 uses a different codeset then a standard tivo remote, sorry. You can purchase the th22 peanut on directv.com, under remotes look for the RF tivo remote for sale.
Edmund is offline
post #8 of 38 Old 06-27-2013, 05:05 PM
DGF
DGF's Avatar
Liked: 39
Originally Posted by Edmund View Post
Reading your other thread at sat guys........
DGF is offline
post #9 of 38 Old 06-27-2013, 07:21 PM - Thread Starter
sportman1's Avatar
Edmund a little confused could you please post a link to the th22 peanut remote which goes with my Direct tv Model Receiver HR34-700
post #10 of 38 Old 06-28-2013, 02:25 PM - Thread Starter
sportman1's Avatar
Dose anyone know the Model number for this remote DIRECTV TiVo Remote for THR22 or HR2X DVRs please
post #11 of 38 Old 06-28-2013, 03:36 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Probably THIS one.
mdavej is online now
post #12 of 38 Old 06-28-2013, 04:14 PM - Thread Starter
sportman1's Avatar
Is this DIRECTV THR22 TiVo Peanut Remote same model number http://www.amazon.com/Tivo-Series-Replacement-Remote-Control/dp/B0002KJJH8/ref=cm_cr_pr_product_top will it work with the DIRECTV Genie HR34 ?
post #13 of 38 Old 06-28-2013, 05:05 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
No, to both remotes in the last two posts.
remote can be purchased from weaknees, it the remote at the bottom of this page:
http://www.weaknees.com/directv-universal-remote.php
weaknees sells it on amazon as well:
http://www.amazon.com/DIRECTV-TiVo-Remote-THR22-DVR/dp/B007TBBNBS/ref=sr_1_1?ie=UTF8&qid=1372461312&sr=8-1&keywords=thr22+remote
I do not know the actual model #. Its the only directv branded tivo peanut with four color keys.
Edmund is offline
post #14 of 38 Old 06-30-2013, 10:16 PM
dpryor123's Avatar
Will the RC34 remote work with the HR44-700 DVR? If so do you have any instructions on how to program the remote to work with the HR44-700? Thank you
dpryor123 is offline
post #15 of 38 Old 06-30-2013, 10:21 PM - Thread Starter
sportman1's Avatar
I am getting the DIRECTV TiVo Remote for THR22 or HR2X DVRs will all the buttons work the Direct tvdvrhd34 ?
post #16 of 38 Old 06-30-2013, 10:51 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
I sure hope you took my advice, and haven't purchased any of the remotes you linked to? Some of the keys that won't work on the thr22 remote with hr34, are the SWAP, THUMBS UP & DOWN, and SLOW. You say you own stand alone tivo, the tv codes in that are the ones the thr22 remote uses, and not the ones in the menu of the hr34.
Edmund is offline
post #17 of 38 Old 06-30-2013, 10:59 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Not via RF, only by IR. Your hr44 has to be in IR mode. when it is, than the rc34 remote using code 00001 should control it.
Edmund is offline
post #18 of 38 Old 07-01-2013, 10:48 AM - Thread Starter
sportman1's Avatar
Edmund
I have Direct tv TIVO Genie HR-34-700 and getting the Remote THR22 or HR2X DVRs will all the buttons work with the Genie HR-34-700?
post #19 of 38 Old 07-01-2013, 11:39 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
I already mentioned what keys won't work your hr34 using the THR22 remote. SWAP, UP & DOWN THUMBS, and SLOW key! again SWAP, UP & DOWN THUMBS, and SLOW, again SWAP, UP & DOWN THUMBS, and SLOW, get it!!!!
Edmund is offline
post #20 of 38 Old 07-01-2013, 11:49 AM - Thread Starter
sportman1's Avatar
Edmund yes I know won't work your hr34 using the THR22 remote. SWAP, UP & DOWN THUMBS, and SLOW key! again SWAP, UP & DOWN THUMBS, and SLOW, again SWAP, UP & DOWN THUMBS, and SLOW, get
What buttons work with the THR22 remote Example dose the
playlist
managing Recordings
Guide
Menu
play
fast forward
forward
mute
what other buttons work ?
post #21 of 38 Old 07-01-2013, 12:58 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
There are no keys for playlist or to manage your recording, you'll find them deeper into the menu using the keys on thr22 remote. One other key that will be useless on your hr34, is the ZOOM key. All other keys should work the same as the hr34 oem remote. To get the Vol & mute keys to control your tv, you will need to go into the menu of your stand alone tivo, to search your tv brands codes out, then enter it into the thr22 remote.
Edmund is offline
post #22 of 38 Old 07-01-2013, 01:08 PM - Thread Starter
sportman1's Avatar
Edmund when you say There are no keys for playlist or to manage your recording, you'll find them deeper into the menu using the keys do not get what your saying will the buttons work for playlist or to manage your recording, with the THR22 remote ?
post #23 of 38 Old 07-01-2013, 01:11 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Go away.
Edmund is offline
post #24 of 38 Old 07-01-2013, 01:19 PM - Thread Starter
sportman1's Avatar
Edmund and everyone I am a disabled person not technical hope you assist me maybe am confused are theses two different remotes hr34 oem remote and THR22 remote ?
post #25 of 38 Old 07-01-2013, 06:37 PM - Thread Starter
sportman1's Avatar
Edmund did you see my message
post #26 of 38 Old 07-01-2013, 07:05 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
The Hr34 oem remote is the remote that came with your receiver, the rc65rx. You may not like it, but it has all the keys that work your hr34 genie. In this thread I told you what keys on the thr22 peanut remote that won't control your receiver, so the ones i didn't list WILL control your HR34 genie. Now wait till you take procession of your new thr22 remote, and test it out yourself. Nothing more needs to be said,unless once it shows up and you can't get it to work, I might be the one that helps you get it to work, who knows until then.
Edmund is offline
post #27 of 38 Old 07-01-2013, 07:16 PM - Thread Starter
sportman1's Avatar
Edmund I will get back to you one things you said won't work your hr34 using the THR22 remote. SWAP, UP & DOWN THUMBS, and SLOW key! again SWAP, UP & DOWN THUMBS, and SLOW, again SWAP, UP & DOWN THUMBS, and SLOW,am I correct
post #28 of 38 Old 07-02-2013, 04:36 PM - Thread Starter
sportman1's Avatar
Edmund guess what I want to know is if HR34 DVRs. is a Genie DirecTV receiver like said here DIRECTV TiVo Remote
for THR22 or HR2X DVRs -
Supports IR and RF. Exact replacement for the TiVo Peanut remote that ships with the new (2012) DirecTV HD TiVo. Not compatible with any other TiVo, from DirecTV or otherwise. This remote will work in IR and RF mode with HR2X and HR34 DVRs. Only IR mode supported in HR44.
post #29 of 38 Old 07-17-2013, 01:06 PM - Thread Starter
sportman1's Avatar
Edmund DirecTV/TiVo Peanut Remote could you tell me the set up
post #30 of 38 Old 07-17-2013, 01:20 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
If you have the right remote, I did already in post 6 of this thread:
http://www.avsforum.com/t/1479178/direct-tv-hd-dvr34-gennie#post_23474004
If you don't have the right remote, nothing will make it work with your Genie. I see the price on the THR22 remote has dropped in price.
Edmund is offline
Reply Remote Control Area
Directv Rc65rx Ir Rf Remote Control , Directv Tivo Remote For Thr22 Hd Dvr
