Finally Replacing my URC MX-900 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-01-2013, 02:45 PM - Thread Starter
JeffNebraska's Avatar
Quoted: 61 Post(s)
I have loved my MX-900 for the incredible power of its programmability, its online updatable database, its RF performance (with a base station), and its great hand feel. However, my select button is going on me. I need to replace it.
Money is not really an object, although I don't want something too flashy. I also don't mind something that takes work to setup, as long as it takes no work to use it. Is there a consensus on the best option(s) today?
Jeffnebraska
Reaching for the Next Level With a Sony 350ES and a 133" 2.35 AT Screen
JeffNebraska is offline
post #2 of 8 Old 07-14-2013, 09:18 AM
sooke's Avatar
Quoted: 100 Post(s)
Liked: 69
I'm in the same boat with my MX-700 remote (9 years old?). Select button is going. I haven't been able to find a suitable new remote. Options I've been looking into:
1) Buy a new URC remote. Nope, can't do that anymore, unless you want to pay someone else hundreds to program it for you.
2) Buy a Harmony remote. Nope, all the new ones have poor reviews, and you can't program macros.
3) Buy the discontinued Harmony One (good reviews, macros, $200 MSRP). Nope. Oh, you can find it on Amazon, but you have to be willing to spend $390.
I think I'll try punching through the select button to the enter button, or one of the programmable buttons, and hope no other buttons wear out before someone makes a decent remote.
Am I missing other options? Is there a good remote out there that can handle macros, and I don't have to pay someone else to program for me?
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
post #3 of 8 Old 07-14-2013, 10:45 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
There are many used mx-700, mx-800, and mx-850's on ebay, which all will use the same PC programming software you already have.
Edmund is offline
post #4 of 8 Old 07-14-2013, 10:48 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
If you have CCP software for your mx-900, do a ebay search for x-7 remote, many are going off cheap. the x-7 is same remote has the mx-780, reason is the bestbuy doesn't have to the price match mx780 on line.
Edmund is offline
post #5 of 8 Old 07-14-2013, 11:26 AM
sooke's Avatar
Quoted: 100 Post(s)
Liked: 69
Hi Edmund. What is CCP software? Where does one get it?
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
sooke is offline
post #6 of 8 Old 07-14-2013, 11:47 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
You don't, it has to come from an authorized dealer, that's if they release to you, its up to them. CCP stands Complete Control Program, used to program such URC branded remotes as mx-880, mx900, mx1200, mx780, x-7, mx890, mx-980.
Edmund is offline
post #7 of 8 Old 07-15-2013, 03:54 PM
Rehan's Avatar
Liked: 26
If you search online for a bit it's not too hard to find URC's Complete Control Program (CCP). URC's official policy is that it depends entirely on their authorized retailers whether or not to release the software to a customer. Some installers are hesitant to do so because it kills an easy profit center for them. Most DIY enthusiasts can figure out how to program their remotes pretty quickly once they have the software and some time to play around with it.
Rehan is offline
post #8 of 8 Old 03-08-2015, 07:56 AM
DeepPurple23's Avatar
I know that I'm too late to this thread to help the OP, but maybe others in the future. I had the same issue with my MX-900. I contacted URC to see if they still sold the 900, telling them the issue I was having. They said send it in, they replaced the pad and the unit is 100% and all it cost me was one way shipping.
Good luck.
DeepPurple23 is offline
Reply Remote Control Area
Universal Remote Mx 900 40 Device Ir Rf Pc Programmable Remote 418 Mhz
