Logitech 900's with Multiple Directv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-04-2013, 10:49 AM - Thread Starter
ambrum's Avatar
I have two televisions (T and LR) with Directv, both set top boxes are in the A/V closet. Both locations are controlled with separate Logitech 900 remotes. Location T with the Genie DVR works great, its set to use the standard Directv remote codes. LR is set to use alternate codes. LR works flawlessly IF the Directv C31-700 is powered on.
For some reason, the signal from remote T will power on both Directv boxes but will not control the LR box after that. It's like LR is accepting all alternate inputs except power on - which it still wants the original. All other functions, including power off work.
Has anyone seen something like this? Any help would be appreciated.
Thanks in advance!
ambrum
ambrum is offline
post #2 of 2 Old 07-04-2013, 10:53 AM - Thread Starter
ambrum's Avatar
I should also note that eliminating the 900's yields that same results. Using the Directv remote for LR it needs to be set in the standard mode to power on, but then the slider needs to be moved to AV1 to continue to control the LR box.
ambrum is offline
Reply Remote Control Area
Logitech Harmony 900 Universal Remote Control Infrared Harmony 900 Rem W Rf Receiver
