Simplest way to use a Harmony IR remote to control a ceiling fan (typically RF)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-14-2013, 10:12 PM - Thread Starter
ThrowingChicken's Avatar
The RF module for my ceiling fan burned out and the remote for it never worked well to begin with, now that they need to be replaced I am hoping I can install a module that uses IR so I can use my Harmony One with it. I know the censor for the IR would need to be exposed, I am sure I could mod something to work, but is there a IR module that would work directly with the Harmony one? I found this auction for a Lutron Maestro module that claims to be IR; Will that work directly with no other hardware required? If not, what do I need? Install a new RF module and use some sort of IR to RF converter?
ThrowingChicken is offline
post #2 of 2 Old 07-17-2013, 05:01 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hi ThrowingChicken, I purchased the Lutron Maestro IR Kit (MIR-LFQMT-WH) and wall plate (CW-1-WH) and it works great with my Harmony One.
JChin is offline
Reply Remote Control Area
Logitech Harmony One Advanced Universal Remote
