Panasonic ut50 codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-15-2013, 08:40 AM - Thread Starter
mortgageman's Avatar
Does anyone here have the codes for the panasonic ut50? Looking for global cache format.
mortgageman is offline
post #2 of 2 Old 07-15-2013, 01:45 PM
mdavej's Avatar
Quoted: 2278 Post(s)
Liked: 992
If that's a TV, than any Panasonic TV codes from the past several years will work. They are all the same.
You can also just grab a JP1 upgrade for that device and generate the codes using IRP Master. You'll also need Remote Master to read the upgrade
mdavej is offline
Reply Remote Control Area
Panasonic Viera Tc P60ut50 Plasma Tv
