Programming a Crestron MX-700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-22-2013, 11:58 PM - Thread Starter
markz12345's Avatar
I have a customer that has an existing Crestron System (3 systems) that he aquired from the previous owner of the house. At this point he only wants to change the Tivo/Comcast box to a Comcast DVR. I have tried uploading from the remote using URC 850 software but failed to recognize. According to a URC tech the 850 software is suppose to work with the mx-700 , that's a normal one not a Crestron one. Is there any work around besides using the Comcast remote?
Thanx for any help.
Mark Z.
markz12345 is offline
post #2 of 3 Old 07-23-2013, 03:26 AM
kdp99's Avatar
I've used an standard MX700 with the MX850 software with out a problem.
Could it be a pc issue ? Can you use an MX850 OK with the MX850 software ?
Are you using a USB adaptor (only some work)
Have you checked the port setting in the MX850 editor ?
Best of luck
kdp99 is offline
post #3 of 3 Old 07-23-2013, 06:47 PM
petern's Avatar
Unless you have the Crestron program file to be able to make changes that way, the Comcast remote is likely your best bet.
petern is offline
Reply Remote Control Area
M K Sound Mx 700 Subwoofer
