MX-850 Incapable of Learning Codes From Comcast XR2? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By srw1000
post #1 of 26 Old 07-23-2013, 04:03 PM - Thread Starter
gfabbri's Avatar
Hi All-
I would really appreciate your help with this.
I have been using the MX-850 remote for a long time and am, for the first time, having issues with it not learning certain functions.
I just got a Comcast XR2 remote with the new X1 system and while the MX-850 was able to learn most of the codes it did not learn:
OK
EXIT
PAGE-DOWN
REPLAY
Obviously, OK and EXIT are critical… very frustrating!
I've tried both the off-line and connected methods of programming. Both appear to work (“Good!” messages), but all tests of these learned codes fail.
Firmware: 1.04
Universal Data (not really applicable…): 1.82
Is it possible that the MX 850 is incapable of learning these codes?
Has anyone had success with this combination of remotes? (If so, any chance you could send me a file?)
Are there other RF/IR remotes that I should use instead (that preferably do not cost megabucks)?
The MX–850 has worked wonderfully until today, but needless to say it needs to perform these functions. I’m tearing my hair out.
Thanks in advance for your help!
-Gian
gfabbri is offline
post #2 of 26 Old 07-23-2013, 06:45 PM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
If you can post the pronto hex of your failed learns plus a few of the successful ones, I'll try to help.
mdavej is offline
post #3 of 26 Old 07-25-2013, 01:47 PM - Thread Starter
gfabbri's Avatar
Update: URC has a new code set, "Cable 195," that solves the problem! It works for both the MX-850 and MX-800 (the only URCs I have), and may work for others.
Props to their customer service!
-Gian
gfabbri is offline
post #4 of 26 Old 07-25-2013, 02:44 PM
DGF
DGF's Avatar
Liked: 39
Originally Posted by gfabbri View Post
Props to their customer service...........
Props to mdavej for offering to help you
DGF is offline
post #5 of 26 Old 07-27-2013, 07:00 PM - Thread Starter
gfabbri's Avatar
Agreed. Thank you for your offer of help, mdavej.
gfabbri is offline
post #6 of 26 Old 07-28-2013, 10:41 AM
mdavej's Avatar
Liked: 940
You're welcome. I have a favor to ask you though. Many people would benefit if you could spare a few minutes and post the pronto hex for all the new code 195 commands, at remotecentral or here.
mdavej is offline
post #7 of 26 Old 07-28-2013, 05:41 PM - Thread Starter
gfabbri's Avatar
I'd be happy to post it, but as a noob, I really have no idea how to do so... I see I need a special receiver(?) and some software to capture the signals(?), or is there another (easier) way to directly convert a .mxf file into pronto hex?
-G
gfabbri is offline
post #8 of 26 Old 07-28-2013, 06:24 PM
mdavej's Avatar
Liked: 940
If you can post a CCF file, I can convert it to pronto hex. But I remember very little about the URC software, so I'm not sure how to make a CCF file.
mdavej is offline
post #9 of 26 Old 11-11-2013, 05:37 PM
TVBill123's Avatar
Where can I get a copy of URC's new code set, "Cable 195," I have a MX-800 and just upgraded to the Comcast Xfinity  X1 box
thx
TVBill123 is offline
post #10 of 26 Old 11-11-2013, 08:38 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
thx
Through your mx-editor, program the cable device, from the cable library, under Comcast. Then look for Xfinity IR only, that should be code 195.
Edmund is offline
post #11 of 26 Old 11-12-2013, 10:17 AM
TVBill123's Avatar
Thanks but the Comcast IR database only goes to 111. any ideas? thx
post #12 of 26 Old 11-12-2013, 01:26 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Try the live update icon, satellite looking symbol, see if it upgrades to allow newer codes like 195?
Edmund is offline
post #13 of 26 Old 11-12-2013, 01:30 PM
TVBill123's Avatar
Live Updates gives you this: "This software can no longer be updated......"
post #14 of 26 Old 11-12-2013, 01:45 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
try the NXG software at remote central:
http://files.remotecentral.com/view/6955-18496-1/nx-rm820_editor.html
The nxg nx-rm820 is a rebadged mx-850.
Edmund is offline
post #15 of 26 Old 02-26-2014, 09:14 AM
nashvegas08's Avatar
Just upgraded to the Xfiniti X1 and have three MX-850 remotes that I need to get working. Can someone help me get the 195 commands. I have the old editor that wont update and it does not have the 195 commands.
Also I tried the NXG software above and it appears to only goes up to command set 151.
nashvegas08 is offline
post #16 of 26 Old 02-26-2014, 12:19 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Under cable> Comcast> xfinity. I have code 195, I don't see 151 under Comcast anywhere.
Edmund is offline
post #17 of 26 Old 02-26-2014, 02:56 PM
On my old editor software the highest code set I see is 111, on the nx-rm820 software listed above the highest I see is 151.
Edmund, which editor version are you using?
post #18 of 26 Old 02-26-2014, 05:22 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
it's 14.01.31.1
Try the B & K SR10.1 software:
http://bkcomp.com/support/software/
Edmund is offline
post #19 of 26 Old 03-04-2014, 07:56 PM
The B&K editor only goes to 111. Still looking for some help on the code set. Anyone?
post #20 of 26 Old 03-15-2014, 06:14 PM
Any ideas? Should I just auction off the remotes I have?
post #21 of 26 Old 03-16-2014, 03:52 PM
srw1000's Avatar
Quoted: 123 Post(s)
Liked: 89
I don't have an MX-850, but I do have an MX-700.
I created a new cable box device, assigned the Comcast code to it, and then exported it as an mxd file, which I've zipped and attached to this post. You may be able to import it with your MX-850 software.
ComcastXfinity.zip 3k .zip file
Good luck,
Scott
MontyTheLab likes this.
srw1000 is offline
post #22 of 26 Old 08-06-2014, 02:46 PM
Quoted: 12 Post(s)
Liked: 0
Wink
<a class="attachment HM-tool loginreq" href="/attachments/76555" title="Comcast cable box codes.">ComcastXfinity.zip 3k .zip file
Good luck,
Scott
Scott, you are a LIFE SAVER! Thank you! It has been FOREVER (09 to be exact) since I programmed my old 850. I dreaded my recent departure from DIRECTV to Comcast just because I had to reprogram the remote. Your file saved my life!! Thank you!!!
MontyTheLab is offline
post #23 of 26 Old 08-06-2014, 08:13 PM
srw1000's Avatar
Quoted: 123 Post(s)
Liked: 89
You're very welcome, and I'm glad to hear it worked for you. That's the benefit of having a great community like this, with users helping other users.
srw1000 is offline
post #24 of 26 Old 10-21-2014, 04:48 PM
Liked: 0
i am contemplating switching from FIOS to XFINITY. My software does in fact update and I can see code 195...does this mean I am good to switch with no problems with my remotes??
dl090465 is offline
post #25 of 26 Old 01-31-2015, 07:54 PM
Liked: 0
Big thanks also, registered to this forum just to thank you.
simonh01 is offline
post #26 of 26 Old 04-02-2015, 08:26 PM
Liked: 0
Xfinity XR5
Just upgraded to Xfinity X1 with the XR5 remote. I have the URC MX-850 remote. Tried the Cable 195 code, but it doesn't work with my Xfinity box. Apparently the IR codes for the XR2 remote are not the same as those for the XR5 remote. Any suggestions?
gfidlon is offline
Reply Remote Control Area
Universal Remote Control Mx 850 Ir Rf Aeros Remote Control
