Does Harmony Smart Control control Z-Wave switches? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-29-2013, 02:22 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I currently have a X10 light switch, however it shuts itself off very often due to noise on the line. I'm looking to replace it with something that doesn't send the on/off signal via the electric lines - hence moving to Z-Wave (feel free to make recommendations).
In the process - I'm thinking of getting a Harmony Smart Control to also control (all my equip is in a equip room away from the home theater room)- does this also control the z-wave switches without need of any additional add -ons?
Also what's the diff between the Harmony Smart Control and the too be released Harmony Ultimate Hub?
Also feel free to advise/recommend other products if you feel it'll accomplish what I need
thx
cgott42 is offline
post #2 of 5 Old 07-29-2013, 03:34 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
No. For Z-Wave, you need to find yourself an old Harmony 890. Philips Hue is what the Ultimate/SmartControl Hub works with. Most other solutions are going to end up doing IR and/or powerline, which you are trying to avoid.
I've had the same issues with flaky X10. If I were in the market today, I'd probably go with Philips. For now, I'm still limping along with X10 as I have the past 15 years.
mdavej is online now
post #3 of 5 Old 07-29-2013, 03:44 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
thanks, though I don't see any Philips Hue wall switches to control existing (fluorescent) light
cgott42 is offline
post #4 of 5 Old 09-30-2015, 08:00 PM
kmiller15211's Avatar
Quoted: 26 Post(s)
This is an older post, but in case anyone needs help with this, maybe they can use this:
I just recently had this issue - I had an old Harmony 890 that was starting to malfunction, and I wasn't sure what to do to replace it. What I did was buy the Harmony Hub (does NOT control Z-Wave directly) and I also bought a Smart Things hub (controls many things including Z-wave, CAN be controlled by the Harmony Hub). Note that the Smart Things hub I purchased was the older model that is now discontinued. I can't vouch for the newer ones coming out around Sept 2015, but I would imagine they would work as well. What I did was first use the Smart Things app on my Smart phone to pair with all of my Z wave lights - I have three Levitron wall switches and two Levitron wall dimmer outlets. Once I had them all working with the Smart Things app, I saved all settings to my Smart things account then I moved to my Harmony app. Inside there, I used this video to assist me: http://blog.smartthings.com/news/sma...rtthings-labs/. Basically, inside the Harmony, you add a device that is a Smart Things hub and then you will have all of the lights controlled by the ST hub inside the Harmony app. It works really well.
Hope this helps you, feel free to email me at kurt at kurtmiller.net if you have any further questions.
kmiller15211 is offline
post #5 of 5 Old 10-02-2015, 10:44 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
I made an IR to Z-wave controller with EventGhost. I use a Vera for Z-wave control. On my remote I programmed in a bunch of commands for stuff I don't have like old VCR number keys. In EventGhost I use the IR commands as triggers and I send out the IP commands for the Vera to control the Z-wave devices. Now VCR number button 1 command turns on my kitchen light and number 2 dims it to 70% and so on. For this to work you just need a computer running 24/7 and an IR receiver, EventGhost is free.
IR is sent to the computer using a universal RF remote to a RF to IR base station. No pointing needed.
bryansj is offline
Reply Remote Control Area
Logitech 915 000194 Harmony Smart Control , Logitech Harmony 890 Advanced Universal Remote Control
