Commercial Skip for Harmony Ultimate on a cable box that is not supported, idea? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-07-2013, 10:25 AM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
I don't see that Cox has this on this cable box. Cisco 8742HDC
Is there a work around?
If not, I've read about some work arounds for boxes not having this.
So here is my idea??????
Can a LONG PRESS also have a sequence and a step added to it?
For instance, if I can time it right I want to do or try this for commercial skip.
Press and hold the >> button to get it in to the long press feature. Have a step added to it so it presses the >> again to get it in 4x FF mode on the DVR. Time it right so that at about 2 minutes (which is about 15 seconds in 4x mode) and then add a step to press PLAY.
But my main question is "Can a long press of the >> button activate a sequence and a step?"
Receiver : Pioneer Elite SC-05
Main Speakers : Phase Technology PC 3.1 Series II
Amplifiers : Emotiva UPA-1 Monoblocks
Subwoofers : Dual Velodyne HGS10
MonsterPower HTS5100
Player : Xbox One & Apple TV
todd1010 is offline
post #2 of 3 Old 08-07-2013, 12:29 PM
mdavej's Avatar
Quoted: 2273 Post(s)
Liked: 992
That should work fine. You can do everything in one sequence, a couple of FFWD's, a couple of delays, then PLAY. But I would make it so the short press is the skip sequence and the long press is FFWD since you'd be using skip more often.
I haven't heard of any discrete codes for skip on a Cisco box, only Moto boxes.
mdavej is online now
post #3 of 3 Old 08-11-2013, 02:04 AM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
What I did works well. I put in 12 second delay after it is FF 4X is just about right.
Maybe I'll play around with it at a faster FF speed to keep the time down!
todd1010 is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote
