Will a Directv remote work with a TIVO XL4 ? - AVS Forum | Home Theater Discussions And Reviews
Old 08-12-2013, 11:04 AM - Thread Starter
sportman1's Avatar
sportman1 is offline
Old 08-12-2013, 12:25 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
The thr22 Directv peanut remote, NO.
Edmund is offline
Old 08-12-2013, 01:16 PM - Thread Starter
sportman1's Avatar
Edmund it is a different question Will a Directv remote 65 work with a TIVO XL4
Old 08-12-2013, 02:49 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
There are 4 codes, 01442, 01142, 20618, and 20739. The last two only works on the av1 or av2 devices, where the first two works in devices accept tv.
These tivo codes are more than 10 years old, So don't look for newer commands like the color keys.
Edmund is offline
Old 08-12-2013, 02:53 PM - Thread Starter
sportman1's Avatar
Edmund what is the steps to entering the codes ?
Old 08-12-2013, 03:13 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
1. dtv or av1 or av2
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 0 1 4 4 2
Only code 20739 will have the Standby command on the PWR key in either av1 or av2 device. None of the others have power commands at all, just like the original peanut. If your tivo is in standby, using the other codes just press MENU to awaken it.
Edmund is offline
Old 08-12-2013, 03:25 PM - Thread Starter
sportman1's Avatar
Edmund the code 0 1 4 4 2 will work the most button for the TiVo Premiere XL4 ?
Old 08-12-2013, 03:34 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
I do not have stand alone tivo, so I can not say which one is suited best for your model? I used 01442 for example in giving the steps, I could have used any one of the 4 codes.
Edmund is offline
Old 08-12-2013, 03:40 PM - Thread Starter
sportman1's Avatar
Edmund tivo codes are more than 10 years old, So don't look for newer commands like the color keys.are their Newer codes will work the most button the color keys for the TiVo Premiere XL4 ?
Old 08-12-2013, 04:03 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Sorry, but no. Tivo is the competition to Directv, the only reason there are any tivo codes in the directv remote is because of the old tivo and directv combo boxes. Which haven't been made since 2005. Last years thr22 doesn't use tivo codes at all.
Edmund is offline
Tivo Premiere Xl4 Tcd758250 Hd Digital Video Recorder
