IR Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2013, 01:27 PM - Thread Starter
mikemar's Avatar
Changed my mind a bit from the RF Thread I started (http://www.avsforum.com/f/93/remote-control-area)
I'm looking to just setup a wired IR setup now. Probably something like this
http://www.amazon.com/Xantech-DL85K-Proof-Designer-Receiver/dp/B0046WZ08U/ref=sr_1_fkmr0_1?ie=UTF8&qid=1377095379&sr=8-1-fkmr0&keywords=WL95+Wall+Link+Universal+IR+Receiver
Then just run that cord and the HDMI in a smurt tube to the receiver's and be happy.
Any recommendations for gear for the IR setup? (probably don't want to do the wall plate IR sensor unless it's the only good one
Doing 2 rooms, so under $250/$300 for both total would be great
mikemar is offline
post #2 of 4 Old 08-21-2013, 01:36 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
I used a Hot Link Pro in the past and liked it fine.
http://www.hot-link.com/pages/products.cgi?mrchcatid=1&mrchid=2
They also have a long distance version where you can use cat5/6 to extend the relay length from the eye to the emitters. That may be useful for you based on the distance you need to go.
http://www.hot-link.com/pages/extra_long_distance_system.cgi
walterappleby is offline
post #3 of 4 Old 08-21-2013, 02:22 PM
Rehan's Avatar
Liked: 25
If you go the IR route instead of using RF one thing to keep in mind is that if you decide to get a remote down the road that allows advanced macro programming (touch one button and it handles powering on the proper equipment and switching inputs) you may find it an inconvenience that you need to keep your remote pointed at the IR receiver the entire time the macro is firing. People tend to push a button on a remote and then drop it on the couch so it might be an issue.
Rehan is offline
post #4 of 4 Old 08-21-2013, 02:23 PM - Thread Starter
mikemar's Avatar
I already have harmony remotes, so we are used to keeping it pointed
But thank you regardless
mikemar is offline
Reply Remote Control Area
Hot Link Pro Remote Control Booster System
