Advice for IR receiver for Windows Media Center Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-04-2013, 07:34 AM - Thread Starter
mcguidance's Avatar
Things are finally coming together. I have the HTPC up and running, now it's time to start tweaking. I've started with Plex for my brother, so he can use plex pass as he travels a ton.
I'm beginning to program my universal remote using the wizard, and I need to set up my WMC remote. I have an HP windows remote with the green button, like this:
http://www.ebay.com/itm/121162652594?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
Now I need an IR USB receiver. Which should I get?
This:
http://www.ebay.com/itm/281154400922?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
Or this:
http://www.ebay.com/itm/190779418793?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
Any help would be appreciated, thanks!
mcguidance is offline
post #2 of 4 Old 09-04-2013, 10:50 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Get the HP. It's proven to be MCE (RC6). The other is an unknown. But for $5, you could take a chance if you want.
mdavej is offline
post #3 of 4 Old 09-04-2013, 09:34 PM - Thread Starter
mcguidance's Avatar
Yep, spent the extra five bucks. Thanks.
Think it will be easy enough to program the mce remote into the urc mx810?
post #4 of 4 Old 09-04-2013, 09:49 PM
mdavej's Avatar
Liked: 940
I don't know much about the MX-810. I would expect most codes to be built in. Otherwise the pronto hex is available many places.
I don't think learning would work very well though, because of the toggle bit in the MCE protocol. I could be wrong.
mdavej is offline
Reply Remote Control Area
