Simple IR Repeater Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2013, 10:05 AM - Thread Starter
captquin's Avatar
I have an IR repeater that someone gave me. Simple set up: the input is on one side of the wall, and the emitters are on the other. I plugged it up yesterday for the first time, and saw the emitter flash red when my wife hit the remote in the other room. However, nothing happed to the component. I put it right over the IR sensor on the box and nothing. It didn't matter how I positioned the emitter (close, far, etc.). Shouldn't it just "repeat" whatever signal I shoot at it, or is there something I'm missing? The signal I tested with is DirecTV
captquin is offline
post #2 of 3 Old 10-12-2013, 10:42 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Is the target DirecTV box in IR mode and set to the same address as the remote in the other room?
mdavej is offline
post #3 of 3 Old 10-12-2013, 08:28 PM - Thread Starter
captquin's Avatar
I think yes to both. Let me make sure I understand the questions.
The target box (the "mini" genie) does receive signal from the IR remote, so I assume it's in IR mode.
The remote is the one from direcTV and it works the target box when it has line of sight. I assume its on the right address, but I'm sure exactly what you mean.
Thanks for your help.
captquin is offline
Reply Remote Control Area
