code for sony bdp-s5100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-27-2013, 07:46 AM - Thread Starter
tailleur's Avatar
I'm having problems programming a sony rm vlz620 to control a sony bdp-s5100. The supplied code does not work. And when I try to teach it commands with the learning function, it fails mid programming.
Has anyone had any luck using this remote with this blue ray player?
Or any other remote for that matter.
thanks,
Matt
tailleur is offline
post #2 of 3 Old 10-27-2013, 09:57 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Many of the vl620 remotes had a learning problem out of the box, it either worked or it didn't. No fix.
As for the preset code 21516, when testing it, see if a small numeral shows up in the front panel of the bluray. It means its set to the right address that matches the code in the sony remote, See your manual on how to switch addresses on the bluray player and oem remote.
Edmund is offline
post #3 of 3 Old 10-27-2013, 10:19 AM - Thread Starter
tailleur's Avatar
actually, i was reading a post on another forum and it suggested that rechargable batteries wont let you program it. So I checked and it did not have rechargables in it but i went ahead and replaced them anyway and "TA DA", it worked. So apparently a low battery will affect the learning function.
thanks anyway,
tailleur
tailleur is offline
Reply Remote Control Area
Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi
