IR codes for Yamaha HTR 6190 and 6160 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-28-2013, 07:19 PM - Thread Starter
ikayhan's Avatar
Hi,
Does anyone have the IR codes for Yamaha HTR-6190 and HTR-6160 receivers?
ikayhan is offline
post #2 of 3 Old 10-29-2013, 07:13 PM
Vincent941's Avatar
Here is a link to remotecentral it is a zip file that has hex code witch is ir code in numbers and letters. All universal remote will let you enter this code for each command it is just time consuming. Hope this helped.
http://files.remotecentral.com/view/2449-4755-1/yamaha_rx-v1800_receiver.html
Vincent941 is offline
post #3 of 3 Old 10-30-2013, 09:32 AM - Thread Starter
ikayhan's Avatar
Thanks a lot
ikayhan is offline
Reply Remote Control Area
Yamaha Htr 6160bl 665 Watt 7 1 Channel Home Theater Receiver
