Is a RF remote possible w/out the repeaters and cords? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-02-2013, 03:45 PM - Thread Starter
met64's Avatar
Quoted: 13 Post(s)
Trying to set up my BR and given the room it is in need something without the clutter. Anyway, the issue is my plasma which hangs on the wall and as such the cords to the RF module are hanging down from it. I tried just putting a piece of black tape over the TV remote sensor but it does not work. Hopefully this makes sense…. Open to suggestions.
Thank you,
met64 is offline
post #2 of 4 Old 12-02-2013, 03:56 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
The Harmony Ultimate can control your TV via Infrared and the rest of your equipment via RF so you won't need a repeater on the TV at all.
met64 likes this.
Dropkick Murphy is offline
post #3 of 4 Old 12-02-2013, 04:14 PM
dalto's Avatar
Quoted: 1239 Post(s)
Liked: 633
Yes, Dropkick Murphy pointed out if your remote supports sending some signals via IR and others by RF that is the best option.
If not, you should be able to conceal the wire in the wall.
met64 likes this.
dalto is offline
post #4 of 4 Old 12-02-2013, 05:57 PM - Thread Starter
met64's Avatar
Quoted: 13 Post(s)
Great… did not know that. Thank you!
met64 is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote
