URC MRF-260 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-07-2014, 06:03 PM - Thread Starter
madhuski's Avatar
Quoted: 629 Post(s)
Liked: 341
I'm trying to connect a Darbee to a URC MRF-260, controlled by a MX-880. Plugging a cable directly into the IR in port doesnt work. I emailed Darbee for help and got the following answer:
"The IR IN on the Darblet expects a pin-out, from tip to sleeve of: (3.3V VCC Out, 3.3V IR In, GND). If an external, powered IR extender is being used, a 3.3V IR signal should thus be present on the ring (middle contact), GND connected on the sleeve, and the tip should be left disconnected (because the Darblet is supplying 3.3V there, expecting an unpowered IR extender)."
they couldn't give me much in terms of follow up support and suggested trying the blaster.
Anyone have any advice?
Selling in AVS Classifieds
Salk Songtower RT
madhuski is offline
post #2 of 3 Old 01-08-2014, 10:55 AM
adk highlander's Avatar
I believe the Oppo BR-83 Blu-ray players are the same way. They sell a cable through there store which I believe should work.
http://oppodigital.com/proddetail.asp?prod=IRAC
adk highlander is offline
post #3 of 3 Old 01-18-2014, 12:53 PM - Thread Starter
madhuski's Avatar
Quoted: 629 Post(s)
Liked: 341
Salk Songtower RT
madhuski is offline
Reply Remote Control Area
Universal Remote Mrf 260 , Urc Mx 880 48 Device Ir Rf Remote With Color Lcd
