NEED HEX CODES GENERATED ASAP PLEASE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-14-2014, 02:38 PM - Thread Starter
Tekwonder's Avatar
I am a Crestron Integrator and I need to tie in a Devaliet System tomorrow.
However, the unit just comes with a BlueTooth remote so I cannot use a learner.
Their website has provided IR codes for control but this is no good for my programmer.  None of the techs have a remote that is capable of spitting back out HEX commands (Marantz, etc)
so I was hoping maybe someone here had one and could help me out and post them back.
Here is the info on their website..
We use the RC5 code modulated at 38kHz which is probably the most common RC code. We support 2 addresses simultaneously - by default 0 and 16. You can modify the addresses through the online configuration tool. If you only need one address, simply duplicate it in the 2 address-lines i.e. 16 and 16 instead of 0 and 16.
Here is the list of commands currently supported along with their respective codes:
RC5_SOURCE_P        32
RC5_SOURCE_M       33
RC5_VOLUME_P       16
RC5_VOLUME_M       17
RC5_MUTE                  13
RC5_BALANCE_L       27
RC5_BALANCE_R      26
RC5_BASS_P              22
RC5_BASS_M             23
Thanks so much!
Tekwonder is offline
Reply Remote Control Area
Marantz
