IR blaster with iTach Flex - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-25-2014, 08:59 AM - Thread Starter
eelton's Avatar
Has anyone successfully used an IR blaster with an iTach Flex? I've been able to get it to work with emitters, but not blasters. I've tried it as a single output or with the tri-cable (with the appropriate blaster setting in setup). It looks like the blaster is glowing continuously when attached as a single device, and not at all when connected to port 3 of the tri-cable.
I'm using a blaster that came with an iTach wf2ir (which works fine with it), and what I believe is the latest firmware for the Flex--at least iHelp doesn't say otherwise. I've tried resetting and reformatting the Flex.
--Eric
eelton is offline
post #2 of 8 Old 01-25-2014, 09:37 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
The Flex is pretty crappy IMO. Go into your iTach settings and set Blaster on IR3 = True and plug your emitter into IR1 and see if that works. This is what I had to do even though I'm not using a blaster.
bryansj is offline
post #3 of 8 Old 01-25-2014, 09:59 AM - Thread Starter
eelton's Avatar
Thanks. I'll try that when I get home. I'm starting to agree with your impression of the Flex.
--Eric
eelton is offline
post #4 of 8 Old 01-25-2014, 12:37 PM - Thread Starter
eelton's Avatar
I can still only get it to work as an emitter, but I bought it specifically to use as a blaster. I put in a support request to Global Cache, but from what I've been reading about the Flex, I'll probably end up returning it.
To sum up my experience with Global Cache products: (1) Avoid the GC-100 and (2) Avoid the iTach Flex.
--Eric
eelton is offline
post #5 of 8 Old 01-25-2014, 01:14 PM
bryansj's Avatar
Liked: 555
On the Global Cache home page there is a notice about a bad batch of blasters. I got a blaster for my co-worker's projector, but it didn't work so we ran an emitter to it. Then I saw the notice about bad blasters, but the emitter cable was already in place and is a better solution. We haven't bothered returning the blaster. In hindsight I should have just got the iTach IP2IR.
bryansj is offline
post #6 of 8 Old 01-25-2014, 04:19 PM - Thread Starter
eelton's Avatar
I had seen that, but the blaster works fine with my wf2ir, in this location.
I just bought another wf2ir on eBay. I'll just stick with these (or the ip2ir) in the future.
--Eric
eelton is offline
post #7 of 8 Old 02-05-2014, 05:49 PM - Thread Starter
eelton's Avatar
To follow up, in case this helps anyone down the road, I found out from Global Cache that the blasters supplied with the wf2ir do not work with the Flex. The Flex requires its own type of blaster.
At any rate, I returned the Flex and bought another wf2ir, which is working fine with the blaster. It's just my opinion, but I would recommend people avoid the Flex (and also the GC-100, for different reasons).
--Eric
eelton is offline
post #8 of 8 Old 08-16-2014, 04:55 PM
jksmurf's Avatar
Liked: 0
I realize this is an old thread but can anyone throw more light on why they think the itach flex is not so good? I am tossing up between that and the ip2ir. Thanks
K
jksmurf is offline
Reply Remote Control Area
Global Cache Ip2ir Itach Wired Tcp Ip To Ir
