logitec harmany 900 remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-14-2014, 09:20 AM - Thread Starter
ropes's Avatar
my remote is about 2 years old and when I put it on the charger, the remote shows a blank screen and will not charge
ropes is offline
post #2 of 4 Old 02-14-2014, 04:33 PM
bryansj's Avatar
Quoted: 1377 Post(s)
Liked: 638
That's about right. You can use an eraser and clean the contacts on both the remote and charger. Otherwise it is probably dead.
bryansj is offline
post #3 of 4 Old 02-16-2014, 05:39 PM
insync44's Avatar
Quoted: 25 Post(s)
From what I've read it seems about the life of these remotes. I have a 900, which is working perfectly. Gives no problems barring an annoying lag. But if I don't put the remote exactly in charger and hear the click, it shows annoying white screen.
insync44 is offline
post #4 of 4 Old 02-17-2014, 09:45 AM - Thread Starter
ropes's Avatar
i tried to clean the contacts and it worked!
ropes is offline
Reply Remote Control Area
Harmony 900 Remote
