AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Remote Control Area (http://www.avsforum.com/forum/93-remote-control-area/)
-   -   Directv remote codes for Denon AVR E300 reciever (http://www.avsforum.com/forum/93-remote-control-area/1518109-directv-remote-codes-denon-avr-e300-reciever.html)
CHAS ZOSS 02-16-2014 04:09 AM
I have been all over the net trying to find the right codes to change the volume on my Denon receiver with my RC65RB remote, I sent a private message to Edmond ( the expert) but got no reply so who wants to help me out?
Edmund 02-16-2014 05:06 PM
When testing codes, don't use the volume keys to determine if it works or not, reason is the volume keys NEVER work initially with ANY audio code. Because the volume keys won't work at all without a tv code programmed to the tv device, once there is a tv code its volume is now in the way, but that can be remedied.
With tv code programmed in, try each denon code, test ALL keys with stereo on. If you come up partially working code, to get the volume:
1. av1 or av2
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 9 9 3
4. press SELECT
CHAS ZOSS 02-16-2014 05:35 PM
why do I need a tv code for volume on the Denon?
Edmund 02-16-2014 06:29 PM
Without a tv code programmed in, the only thing the volume keys and mute are good for is initiating a message at the bottom of the Directv receiver screen, telling you to program a tv code in, yours or any, but there HAS to be a tv code programmed in.
When making up their SAT codes for Directv, both UEI & URC included these IR commands mapped to unprogrammed volume and mute keys in their satellite code for directv.
CHAS ZOSS 02-17-2014 03:07 PM
Edmund, thank you so much. Your the man!
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
