Remote control security camera - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-14-2014, 04:08 AM - Thread Starter
yandexrhino's Avatar
Neo Coolcam IP Camera Review
Along with the raising of theft, home security cameras are badly in need of. Promising to make advanced home security easier and more accessible, Neo Coolcam released this, a monitoring monster which is a private remote controller.
The good: Effectively IR Night Vision mold Neo camera an eagle eye, barrier-free spying in the darkness. Both vertical and horizontal rotation are supported. Simply remote control it by your smartphone through the Internet.
The Bad: This security camera is not a flexible and portable one. The combination of the organs is not so tight. It lacks a unique drive contained in itself, a disk is needed to finish the installation
The Bottom Line: All around vision wireless camera achieve almostly peer-to-peer. For customers who already own an Android or IOS smartphone are capable to view their recorded footage. The camera features a resolution of 720p lens. Costing $52 low price, which is less than you’ll pay for well-reviewed competitors Dropcam.
Appearance
To put it bluntly, Neo Coolcam security camera resembles to a robot dog. You can straightly divided it into 3 parts. A main body, a foundation and the tail.
Based on the foundation, there is a circular platform which is connected to 2 ears of the head. Between the 2 ears, a column is caught in the middle. The lens is attached to the column, Night Vision IR LEDs are equalized distributed around the lens.
The foundation
This part is seemed simply. You can see the logo when it faces to you. At the bottom of it, three triangle-lined cushions stably support it. If unsatisfied with the height of the camera, an included bracket could be assembled to the tapped hole in the middle. A reset hole is set on the edge.
The tail
Coming to the back side, a cuboid box contains the connecting components. From left to right, as you see in the picture, an Audio port, an RJ45 Ethernet port, an antenna, an alarm input and a 5V power adapter port are in turn. The antenna can be folded.
Installation
Honestly, Neo coolcam offers easy set up and flexible mounting options.
First of all, wired linking. The priority is to link Ethernet port and DC 5V adapter. You may connect the Ethernet cable to a router or a switchboard to transmit the signals. Certainly, providing an earphone or an alarm if necessary.
Second, create a drive for the device. Putting the disk into the CD-ROM and reference the description to operate step by step.
Third, network connecting. Make sure that the drive for your device is existed. Open your browser, input the IP address and execute. An complicated IP CAM setting interface shows up. Don’t worry, all you need is just to set up the administrator’s name and the same IP to your computer.
At last, you are able to employ it as your home safety bodyguard.
Features/Experience
1.      IR Night Vision
People doubt about the night vision of security cameras. We took some photos of our experience. 720p lens with IR red lights around, the image is really not bad in 10 meters. Adequate illumination though we turn off all the lights. Not guarantee for recognizing the face but be sure for the behaviors.
2.      PTZ rotation system
Pan/Tilt Horizontal 270 degree rotation by the circular platform and Vertical 120 degree by the middle column supplies a comprehensive monitor. Spinning velocity is slow, which makes you easy to control. For adjusting and preheating, rotation will be launched for a while as you connect it to the adapter.
3.      Wireless IP
To remote the device, we don’t use any kind of cables. We randomly chose a computer in the other room and enter the IP address after finish linking up the Ethernet cable and DC. Signal communicated soon. The whole process is fluently without delay.
At the meanwhile, Android phones and Iphones are capable to manipulate it via apps.
4.      This camera features a speaker and microphone so you can both hear
what's going on in a room and talk to anybody in the room through the camera.
Appearance
The foundation
The tail
Installation
Features/Experience
1.      IR Night Vision
3.      Wireless IP
yandexrhino is offline
Reply Remote Control Area
