I Lost My Remote Control for my Samsung TV. Will a Generic Remote Work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-24-2014, 11:20 AM - Thread Starter
BeachBumm2's Avatar
I'm glad I found this board!
I have a Samsung Plasma PN50A650.  I recently moved and can not
find the remote.  I saw a couple of remotes on Amazon that are
generic remotes that "claim" to work with my TV.
Will a generic remote work?
I don't watch much "TV", but would like to watch it occasionally, especially
with the Stanley Cup & NBA playoffs happening.
BTW... any info on the cheaper generic remotes sold at Best Buy?  I
hate that store, but would force myself to shop there one time, just to
get my TV up & running again..
Any suggestions?
BeachBumm2 is offline
post #2 of 16 Old 04-24-2014, 07:17 PM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
The best cheap remote, IMO, is the RCA RCRP05B. It will work fine with your TV, and unlike other cheap remotes, can do every possible function of almost any device without needing to learn from the original remote. I'm not sure if they're at your particular Best Buy, but you can get them at many other local places.
mdavej is online now
post #3 of 16 Old 04-24-2014, 08:40 PM - Thread Starter
BeachBumm2's Avatar
Thanks for the tip.
I can not find the RCA RCRP05B anywhere around here.
Got any other suggestions?
post #4 of 16 Old 04-24-2014, 09:47 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Originally Posted by BeachBumm2 View Post
Thanks for the tip.
http://www.amazon.com/RCA-RCRP05BR-Device-Replacement-Universal/dp/B0028IKXLS
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 16 Old 04-25-2014, 07:25 AM
mdavej's Avatar
Liked: 940
... also try Staples, Office Depot, Walmart, Sears, Walgreens, Radio Shack, Target. RCRP05BR is identical to the RCRP05B. The setup code you need to use is TV 0812.
post #6 of 16 Old 04-25-2014, 10:45 AM - Thread Starter
BeachBumm2's Avatar
Bummer... some of them have this remote 'online'' but not in the stores.
Big NBA game tonight.
For the most part, or "any" of the 4 or 5 device aftermarket remotes ok
for a Samsung TV?
post #7 of 16 Old 04-25-2014, 12:05 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
for a Samsung TV?
I'm using the 6 device and 8 device versions of this remote with Samsung TVs and they both work fine > http://www.bestbuy.com/site/4-device-universal-remote/1088116.p?id=1218219329422&skuId=1088116&st=rca remote&cp=1&lp=5.
Vin
Vin is offline
post #8 of 16 Old 04-25-2014, 11:01 PM - Thread Starter
BeachBumm2's Avatar
I could not find that remote here locally, so I bought a One For All #oarusb04g.
Will the setup code TV 0812 that you gave me work for this control?
Is that a code number for any remote for my tv?
BTW - where did you find that code?
post #9 of 16 Old 04-26-2014, 06:52 AM
mdavej's Avatar
Liked: 940
Yes, same code. Press TV, hold setup for 2 blinks, enter the code. That's an excellent remote BTW. I have one too. It has some nice macro capabilities and a great layout.
Each remote maker uses different codes. Coincidentally, UEI makes both one-for-all and that RCA I suggested, hence they have the same codes.
I found them from the links in my signature plus some detective work when opening the device upgrade file for your TV found in the JP1 file section, and the fact that most samsung TV codes haven't changed in 15 years.
post #10 of 16 Old 04-26-2014, 10:47 AM - Thread Starter
BeachBumm2's Avatar
I can not get the darn thing to take the code!
post #11 of 16 Old 04-26-2014, 01:51 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
I doubt this will help with TV 0812, but in general for this remote, the sequence to enter a setup code should be:
Press Setup until 2 blinks
Press the desired device button
Enter the setup code.
This order is different to most UEI remotes, but for any device besides TV, this seems to be necessary. BTW, I did check with my OARUSB04G, and it accepts TV 0812.
3FingeredGlove is offline
post #12 of 16 Old 04-28-2014, 11:20 AM - Thread Starter
BeachBumm2's Avatar
Does anybody know where I might find the settings for my particular TV?
It seems a bit dark these days.  I remember there was a published list of settings
that made the picture w-a-y better than the factory settings, but do not have the
link any longer.
post #13 of 16 Old 04-28-2014, 12:23 PM
mdavej's Avatar
Liked: 940
Should be lots of settings in this thread:
http://www.avsforum.com/t/1029240/samsung-pn58a650-owners-thread/0_100
I assume you got the OARUSB04G working?
post #14 of 16 Old 04-29-2014, 10:20 AM - Thread Starter
BeachBumm2's Avatar
Thanks Mdavej, and yes, I got the remote working!
post #15 of 16 Old 01-21-2015, 10:44 PM - Thread Starter
BeachBumm2's Avatar
I began this thread last April and have another question regarding this same remote.
Is this thread still active?
If it is, I'll post it here, otherwise I can start a new thread...
post #16 of 16 Old 01-23-2015, 06:11 AM
mdavej's Avatar
Liked: 940
It is now. Follow the Xsight link in my signature to get Remote Master software and add any codes or activities you can imagine. A lot has changed since you started this thread.
Reply Remote Control Area
