Which Remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-09-2014, 12:08 PM - Thread Starter
carlb54's Avatar
Hey, I'm offered either a Logitech® Harmony® Ultimate Remote or a URC -R40. My system includes HT with Yamaha A3030, 5.1 with seperate Sub Amp, zone2 Outdoor Screen with projector and 2 speakers, Zone3 2.1 rock speakers. Blue Ray, Cable Box.
I need stable RF with either Android phone or Ipad control.
Any thoughts/suggestions?
Carl
carlb54 is offline
post #2 of 6 Old 06-09-2014, 12:37 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Carl
The URC-R40 has no phone or iPad control, so that's out. Given your requirements, you don't need a remote at all, just iRule and a Global Cache gateway, assuming you don't want to deal with a bunch of separate apps for each device. Your projector and cable box probably don't have any apps available anyway. The Ultimate should also work fine, and the touch screen shouldn't bother you, since that's what you want.
mdavej is online now
post #3 of 6 Old 06-09-2014, 12:38 PM - Thread Starter
carlb54's Avatar
thanks for the input. I research irule. new to me.
carlb54 is offline
post #4 of 6 Old 06-09-2014, 12:52 PM - Thread Starter
carlb54's Avatar
Wow.... Lots to like with iRule. Any ideas on waterproofing the controller of choice? Ipad, etc.... This unit will pull major pool, tiki Bar duty.
thanks again.
carlb54 is offline
post #5 of 6 Old 06-09-2014, 02:19 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
thanks again.
Start with a waterproof device.
bryansj is offline
post #6 of 6 Old 06-09-2014, 08:29 PM - Thread Starter
carlb54's Avatar
Ah yes. The lost art of the obvious and brevity.
carlb54 is offline
Reply Remote Control Area
