RS-232 control of 2014 Samsung - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-01-2014, 11:49 AM - Thread Starter
Liked: 0
I am looking to control a couple of new Samsung tv's with RS-232. I have two LG monitors currently installed in my motorhome controlled by Crestron and I want to update to the 7150 for one and a 6350 for the other (size limitations). The specs both say they have RS-232, but nobody at Samsung seems to know what I can get them to do. Basically, I need the ability to turn on, turn off and select the input. Other things may be nice in the future, but that is what I am using now with the older LG's.
The other thing is what do they use for connectors for the RS-232? Is it a DB9 or a 3.5 mm audio jack? I have been told both by Samsung. I have not found any to look at yet, hence the questions.
Mark3101 is offline
post #2 of 3 Old 07-12-2014, 09:48 AM
Glackowitz's Avatar
you will need a DB9- to stereo mini, it will plug into the EX-Link port on the back of the TV.
DB9--- Stereo mini
2---------- tip
3 --------- ring
5--------- sleeve
Crestron should have a module as well
Glackowitz is offline
post #3 of 3 Old 07-13-2014, 08:11 AM - Thread Starter
Liked: 0
Thanks much for the info. I will proceed on the project.
Mark3101 is offline
Reply Remote Control Area
