Pronto Edit 4 on Windows 8.1 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By lovebuzz#836
post #1 of 3 Old 07-04-2014, 11:48 PM - Thread Starter
sgndave's Avatar
I'm using Pronto Edit 4 (for my TSU-1000 remote) on Windows 8.1. It worked under Windows 7, but on Windows 8.1, it doesn't see my com port, so I can't connect to my remote.
I'm using a USB to Serial adapter. The adapter works with other devices, and it shows up as Com 3 in the Windows Device Manager, but Pronto Edit 4 doesn't see it. Again, this configuration (same USB to Serial Adapter on this same PC) worked with Pronto Edit 4 under Windows 7, and it works under Windows 8.1 when connecting to other RS-232 devices. It's just that Pronto Edit 4 doesn't recognize it as a Com port (whereas other software programs do recognize it as a Com port) on Win 8.1.
I've tried running Pronto Edit 4 in compatibility mode (tried both Win 7 mode and Win XP mode), and I've tried running it as Administrator, all with no success. I've also tried uninstalling and then reinstalling Pronto Edit 4.
I'm trying to avoid reinstalling Win 7 (as either dual boot or a VM), and I'd rather not install an actual RS-232 card if I can avoid it (the last one I had wasn't compatible with Win 8.1, so I had to remove it).
Anyone else run into this and find a solution? Any other ideas?
sgndave is offline
post #2 of 3 Old 07-05-2014, 03:07 AM
lovebuzz#836's Avatar
It has been years since I've had a Pronto, but iirc the Pronto Edit software was looking for COM1 designations for the units. I don't have Windows 8.1, but changing the COM port on it shouldn't be too different than this:
http://plugable.com/2011/07/04/how-t...r-on-windows-7
sgndave likes this.
lovebuzz#836 is offline
post #3 of 3 Old 07-05-2014, 12:44 PM - Thread Starter
sgndave's Avatar
That was it! You're awesome! I changed it to Com 1, and it works perfectly. Nowhere in the documentation does it mention that limitation. I don't even need to set compatibility mode or run as administrator. Thanks so much!
sgndave is offline
Reply Remote Control Area
