MX-5000 Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-05-2014, 04:14 PM - Thread Starter
ekkoville's Avatar
MX-5000 Remote
Currently I have three MX-900 remotes and at least two have issues with the buttons sticking or not responding well. I'm considering replacing them with an MX-5000 to gain touchscreen and IP capabilities. I'm wondering if anyone has one and has programmed it? It looks great and like a real nice upgrade.
ekkoville is offline
post #2 of 8 Old 07-07-2014, 12:52 PM
topp's Avatar
Quoted: 13 Post(s)
I have one. But haven't programmed it much. Decided it wasn't really my cup of tea and is more then I need. I would sell it if your interested.
Topp
topp is offline
post #3 of 8 Old 07-09-2014, 06:04 AM - Thread Starter
ekkoville's Avatar
Topp
Sorry for the late reply. I've been looking at the manual from URC and it seems like the wifi portion is more for feedback than to send IP commands. Still looking at it but I am hoping for something that can send IP control commands as well RF to IR stuff. What exactly have you programmed?
post #4 of 8 Old 07-09-2014, 10:36 AM
topp's Avatar
Quoted: 13 Post(s)
I am pretty sure the MX-5000 can send IP commands, but it might be limited to what devices. I pretty much just programmed it to control my TV, receiver, Blu ray, etc.. using RF/IR. I didn't see my TV listed in the IP pull down, so didn't look much further. I probably should see if my blu ray player is listed, since that might be a little more popular.
Question, why do you want/need the IP part? Wondering if I am missing the benefit, therefore the desire to dig deeper into it.
topp is offline
post #5 of 8 Old 07-09-2014, 11:50 AM - Thread Starter
ekkoville's Avatar
Well I thought maybe that I could send an IP command to my Sonos system for transport controls. Also, I have a Sony Blu-ray and a Marantz SR6006 that I'd like to use it on. But the Sonos was my big question, hoping it wasn't just UPnP commands that needed to be sent. I can send IP transport commands now to Sonos with iRule so I'd hoped I could get a wand style remote to do the same thing.
post #6 of 8 Old 07-09-2014, 12:23 PM
topp's Avatar
Quoted: 13 Post(s)
If I have time tonight I can check and see in the IP section if Sonos exists. Quick google search looks like the Total Control line of remotes from URC, might be able to do the Sonos, but those don't show up much used and finding the programming software for that is about impossible.
topp is offline
post #7 of 8 Old 07-09-2014, 07:02 PM
topp's Avatar
Quoted: 13 Post(s)
I just checked I don't see Sonos in the CCP (complete control program) IP pull down.
topp is offline
post #8 of 8 Old 08-06-2015, 09:45 AM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
I'm bringing this back from the dead, but in case anyone is interested.
Yes, the MX-5000 works as a IP remote. I'm using to control a Marantz AV7005, Tivo Premier, and even a Kodi based HTPC. I was using IR control of the HTPC but tried IP as I was frustrated in getting IR control to work smoothly (slow, missed signals,etc). I tried both a MSC-400 and a MRX-1. Neither were near as fast or consistent.
FYI - for Kodi I'm making json calls, IE {"jsonrpc":"2.0","method":"Input.ExecuteAction","P ageUp","id":1}. They work consistently and they're fast.
BizarroTerl is offline
Reply Remote Control Area
