Harmony Ultimate with hub quick question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-13-2014, 07:53 PM - Thread Starter
gowingsgo1974's Avatar
Didn't want to read through a million posts if someone had the quick answer to a novice question.
Doing a dedicated theatre room. My Uverse cable box, blu ray player, and Receiver will all be in an adjoining closet next to the theatre.
The Harmony Ultimate with HUB will operate those items correct?
Thanks for your help!
gowingsgo1974 is offline
post #2 of 3 Old 07-13-2014, 08:08 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
You really have to go online and check to make sure all the models of components you have are supported. You don't have to buy the remote to find out. If it does support all your devices and most likely it does then yes the hub should do what you want.
I have 14 devices and 11 activities created already. I still need to add more activities. The remote with hub works great. You will need the ultimate if you want support for more than 8 devices.
Ronomy is offline
post #3 of 3 Old 07-13-2014, 08:39 PM - Thread Starter
thank you
Reply Remote Control Area
