Control a CCTV DVR from 8 different TV's? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mdavej
post #1 of 3 Old 07-27-2014, 06:53 AM - Thread Starter
Liked: 0
Hi,
I am about to start wiring for a new project in my house. My goal is to be able to view my CCTV DVR feeds on each and every TV in the house. So far I am thinking that my set up will be something like the following:
10 x IP Cameras <-----> CCTV DVR <----> 1 to 8 HDMI SPLITTER <------> 8 x TV's
This would allow me to view the CCTV feeds on all TV's but is there a device which would allow me to control the CCTV DVR via 8 remotes which would be next to each TV? So, 8 receivers with 8 remotes and 1 transmitter connected to the CCTV DVR. If not a device capable of 8, then maybe 6 or 5?
Or if anyone can think of any other method to view AND control the CCTV DVR feeds on all TV's in the house other than what I have outlined above I would be very much appreciative. I have the house open an ready to be wired with pretty much anything at the moment, CAT5e/CAT6/Fibre Optics/Coax.
Many thanks in advance
Shaolin
Shaolin666 is offline
post #2 of 3 Old 07-27-2014, 07:58 AM
mdavej's Avatar
Quoted: 2063 Post(s)
Liked: 926
Simplest solution would be Next Generation RF base plus 7 additional Xmitter batteries (all the same frequency), $180 total. No limits that I know of besides distance (60' give or take, depending on walls and materials).
http://www.amazon.com/Next-Generatio.../dp/B000C1Z0HA
Since you have the walls open, you could also wire for IR everywhere or use IR over existing coax.
http://wiki.hometech.com/tiki-index....ution+Tutorial
There are probably lots of other solutions (IP, etc.).
Shaolin666 likes this.
mdavej is offline
post #3 of 3 Old 07-27-2014, 10:37 AM - Thread Starter
Liked: 0
WOW!
Lots of reading for me to do. Many thanks for taking the time to reply in such a thorough manner. I will report back once I have decided upon a suitable method to conclude this thread in the hopes it might assist others.
Thanks again.
Shaolin
Reply Remote Control Area
