Will using Logitech 700 help improve connection with devices? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-02-2014, 02:51 PM - Thread Starter
butie120's Avatar
Quoted: 365 Post(s)
Liked: 74
Right now I own the Denon 2112CI and the Sony S5100 Blu Ray player. I like both of these devices, but what irks me is that I don't think they use RF technology. My entertainment center is in the back of the room and my projection screen is in the front of the room. In order to use my current remotes I have to hold the remote to the side or near the back in order for them to respond to the player.
My question is this: Will getting a Logitech 700 provide me the ability to point the remote forward or do I need something else in order to help make this happen? Any info would be great! Thanks!
butie120 is offline
post #2 of 4 Old 08-02-2014, 07:39 PM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
You need an IR repeater, a mirror or an RF remote. The 700 will work exactly like your current remote.
mdavej is offline
post #3 of 4 Old 08-03-2014, 07:03 AM - Thread Starter
butie120's Avatar
Quoted: 365 Post(s)
Liked: 74
Thanks mdavej. I actually quoted you in a different post. I'm looking into the Next Generation remote extender, but curious if I will need to buy anything other than the product on Amazon going for $39.99. Will this suffice for my needs?
butie120 is offline
post #4 of 4 Old 08-03-2014, 01:21 PM
mdavej's Avatar
Liked: 940
That comes with one transmitter and one receiver. I don't know if that's all you need or not. If you only have one room and one remote, then yes.
Next Gen doesn't work on an recent Harmony models.
mdavej is offline
Reply Remote Control Area
