Harmony 650 with PS3 Nyko Blu Wave - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-07-2014, 02:09 PM - Thread Starter
krdell's Avatar
I used to have this working properly but I have since moved and reset my configs and on top of it all, lost the original Nyko remote. At any rate, I am trying to add it back to my Harmony remote with the dongle plugged into my PS3...I can add the Nyko to the remote using the software then syncing it with remote, but it doesn't actually work with the IR dongle, no commands whatsoever. The USB dongle still works but I am not able to get it to accept any commands. Do I need to buy a new one (with remote) and manually program the commands?
krdell is offline
post #2 of 5 Old 08-07-2014, 02:47 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Nyko used a couple of different code sets over the years. So first, I'd try another Nyko from the logitech database if possible. The most common used a Sony DVD code set. So worst case, pick a Sony DVD player profile (any recent model) and try that.
PM me if you want another Nyko cheap. I got rid of my PS3 a long time ago and have no need for it.
mdavej is offline
post #3 of 5 Old 08-07-2014, 03:15 PM - Thread Starter
krdell's Avatar
Any easy way to see a list of models or do you have any to recommend? It basically asks me to enter in a specific model in the field. Thanks for the reply
krdell is offline
post #4 of 5 Old 08-07-2014, 04:06 PM
mdavej's Avatar
Liked: 940
Try Sony DVPSR210P. That seems to be a popular model. Failing that, just search for other models. All use the same codes.
mdavej is offline
post #5 of 5 Old 08-08-2014, 06:01 AM - Thread Starter
krdell's Avatar
Yep that worked. Thanks!
krdell is offline
Reply Remote Control Area
