If anyone has been successful in getting the Xfinity X11 voice controller remote to turn a Yamaha RX-V663 receiver on and off and control the volume, I would be very grateful if you could step me through the process. I have tried all the codes that Comcast provides as well as their "Setup + 992 + channel up" search approach in an attempt to locate the correct code with no success. Please let me know if you have a solution. Thank you.
You will not find a single code that powers your Yamaha both on & off, its one or the either, never both with single code. Because of yamaha's use of two-key power scheme, one command for on, and another for standby.
You try each code with Yamaha both on & off? If its on, code with on command would seem not to work. And volume is probably being over ridden by the tv volume out of the box.
I have tried with both the Yamaha RX-V663 ON and with it OFF. I have tried entering the "toggle" code and the "discrete" codes, neither approach works. After entering the (($ code the X11 blinks green twice. No matter what I type after pressing and releasing the setup ke after the remote blinks twice registers. No indication of anything and when I test the buttone, they do nothing.
If you're referring to advanced codes, you're probably trying them on remote that doesn't accept them, newer UEI remotes don't.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
