Loewe / Bose / Sony - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2003, 05:51 PM - Thread Starter
thegratingone's Avatar
I have a rather exclectic system upstairs, a mixture of a top notch Loewe TV, with a simple bose speaker/receiver, and a simple sony DVD/CD player. I don't really understand much about universal remotes. Are there any I can train for all of these? If so, how hard is it? I'm particularly concerned about the Loewe as it's not very mainstream.
Sorry if this question is really ignorant, and thanks in advance.
thegratingone is offline
post #2 of 3 Old 01-04-2003, 07:27 PM
AnthonyP's Avatar
I don't know much about Loewe, but Bose uses RF and that would be a problem. What model Bose do you have. I think the 35 and 28 can also do IR, but the rest cannot. You could try contacting Bluedo.com, they have a device that can talk to Bose receivers in RF, but you would need to make sure it works with your stuff and you would be limited in the remote you can use.
AnthonyP is offline
post #3 of 3 Old 01-04-2003, 07:59 PM - Thread Starter
Thanks, that's helpful. I'm pretty sure the 3*2*1 system is IR (please don't ask why I have a 3*2*1 hooked up to a Loewe!). Believe it or not, I didn't even know that these universal remotes could learn IR commands (I thought they all had to be preprogrammed).
Closed Thread Remote Control Area
