Hex codes for Samsung SIR-TS160 HD Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-06-2003, 11:44 AM - Thread Starter
novo2's Avatar
Does anyone have discrete hex codes for the samsung SIR-TS160 HD receiver
-Thanks
novo2 is offline
post #2 of 8 Old 01-06-2003, 10:25 PM
jtandy's Avatar
I emailed Samsung tech support and they told me that discrete codes didn't exist.
jtandy is offline
post #3 of 8 Old 01-14-2003, 03:35 PM
jswclw's Avatar
So does this mean that one of these "Pronto" type remotes cannot run a T160? I have a T150, same problem?
Jeff
jswclw is offline
post #4 of 8 Old 01-14-2003, 03:50 PM
jtandy's Avatar
It should only mean that you can't set up macros for power on and power off and include the Samsung in those macros. All tech support told me was that there were not seperate codes for power on, power off, HD, and SD modes. I don't know about being able to control the unit as a whole.
Joe
jtandy is offline
post #5 of 8 Old 01-14-2003, 04:53 PM
HNick's Avatar
Several companies (notably Panasonic) make TOADs (toggle activated only devices). With a Pronto, for example, you can still learn the codes from the remote, but they'll be TOADs. I have this problem with my Panny VCR and just keep track of where it is (on or off). As mentioned by Joe above, you really can't put them in a macro. HNick
HNick is offline
post #6 of 8 Old 01-14-2003, 06:16 PM
HNick's Avatar
I should have added that not all Panasonic devices are TOADs, just some. However, I couldn't find discrete codes for any Samsung equipment.
Also, I'm sure there are other remotes that "Learn" - I just don't have any experience with them.
HNick
HNick is offline
post #7 of 8 Old 01-17-2003, 09:32 AM
jhutchey's Avatar
There are dicrete on/off codes for the TS160 posted on remotecentral.com. Check out this thread there:
http://www.remotecentral.com/cgi-bin...thread.cgi?701
-John
jhutchey is offline
post #8 of 8 Old 01-17-2003, 12:46 PM
Steve*Moore's Avatar
Does anyone have a CCF for the SIR-T165? Please IM me if you are willing to give me a copy.
Steve
Come to the Summit, the View is Superb!!
Steve*Moore is offline
Closed Thread Remote Control Area
