FYI Harmony Remote deal at CES - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-11-2003, 12:37 AM - Thread Starter
trunks's Avatar
CES over. So show deal == gone.
Jake
trunks is offline
post #2 of 8 Old 01-11-2003, 08:25 AM
AnthonyP's Avatar
you can read what I wrote in this thread http://www.avsforum.com/avs-vb/showt...hreadid=210929
BTW if you want you can register on Harmonyremote.com even if you don't have a remote. So you can start configuring and seeing what the programming is like even without the remote
AnthonyP is offline
post #3 of 8 Old 01-12-2003, 11:18 PM
John Rossi's Avatar
saw it there as well and decided to hold off a bit. keep us posted with your experiences.
John Rossi is offline
post #4 of 8 Old 01-13-2003, 05:58 AM
AnthonyP's Avatar
the remotes are good, and powerful (probably the most configurable hard button remotes there is). Most basic setups (i.e. setups that fit most people) are done through wizards (i.e. for watch TV it will ask what display device to use from your list, then what do you use to listen, what do you use to change channels.....). And then the activity is done. You also have sub activities (for instance I used the change button function under my watch TV to add the VCR controls since I tend to watch prerecorded shows during the ads). The remote has good IR range. The only other draw back is that the LCD (not the back light) is always on, so it does tend to eat batteries.
but if there is anything in particular you want to know, just ask.
AnthonyP is offline
post #5 of 8 Old 01-13-2003, 10:42 AM
John Rossi's Avatar
thanks much for the info
post #6 of 8 Old 01-13-2003, 11:20 AM
scottb80's Avatar
Originally posted by trunks
I was just at Harmony Remote's booth at CES today. I ordered a 745 for $80. I think they were selling the 768 for $130 or $140.
Out of curiosity, I sent Harmony an email, asking for the above prices. I got a very cordial "no" from them with the explanation that that was a show price only, and then, only for dealers and reps, supposedly. I can't knock me for trying. :D
Anyone using a Harmony remote with a Samsung DLP set? I logged on to their web page and found out that the HLM series of Samsung sets is not covered. :(
Scott B)
scottb80 is offline
post #7 of 8 Old 01-13-2003, 01:23 PM
MikeSRC's Avatar
If your particular model or brand is not listed in the current Harmony database, you can learn the IR from your Samsung's remote to the database. It will usually match that up with an existing code set that will work. Even if that fails, there's still the ability to learn each individual command into your configuration.
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #8 of 8 Old 01-13-2003, 03:17 PM
scottb80's Avatar
I sent Harmony Support an email, and they said the Samsung DLP codes would be moved into the library this week. :) Looks like I'm in the market for a Harmony 768.
Scott B)
scottb80 is offline
Closed Thread Remote Control Area
