IR setup question(in a A/V cabinet) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-12-2003, 12:48 PM - Thread Starter
vfrjim's Avatar
I asked it in another section of the board and getting no replies, maybe it should have been asked here: http://www.avsforum.com/avs-vb/showt...hreadid=212092
If anyone has ideas, I would like your input,
Jim
Support C-band, the only true satellite signal, More information HERE
vfrjim is offline
post #2 of 9 Old 01-12-2003, 04:30 PM
HNick's Avatar
Jim,
I've used a lot of Xantech stuff with excellent success. I have all my equipment in the basement, except the speakers and projector, which are in the family room.
I presume the remote will NOT have a direct shot at the AV cabinet. If it will, you need to prevent the remote (direct) signal from interferring with the relayed signal. Also, I sent you a PM. HNick
HNick is offline
post #3 of 9 Old 01-12-2003, 07:48 PM - Thread Starter
vfrjim's Avatar
It may have a direct signal at times, what will happen if it gets both signals? But I could always put the emitters over the component's IR receiver to prevent it. Also, I cannot find out if you can Wire 2 Receivers at the same time, so that I can have one near my av equiptment and one where my other TV is at, in physical distance from each other, they are not more then 15 feet, but on different floors.
Jim
vfrjim is offline
post #4 of 9 Old 01-12-2003, 08:04 PM
HNick's Avatar
Two signals...?
Xantech makes emitters that are both IR transparent and IR opaque (get the opaque kind). I always mount the emitters over the component sensors.
...near my AV equipment...?
Which is the one you would use most of the time, presumably.
...one where my other TV is at...?
Yes you can do this, but you'd need two Xantech receivers, conn blocks, emitters for each component, and power supplies. There is another way to do it, but it adds another level (or two) of complexity and cost. It's a distribution system (that Xantech also makes).
And before anybody asks, yes, you can control two of the same device (like two Sony TVs that take the same IR codes) independently with one remote. BUT this also adds a level of complexity (cost) that most people don't want to do. You need an IR router (Xantech again) and a remote that can learn special codes. HNick
HNick is offline
post #5 of 9 Old 01-12-2003, 11:13 PM - Thread Starter
vfrjim's Avatar
More or less, I wanted to wire two IR Micro Links in series so that I can have one in one room and the other in another room, is that possible?
Jim
vfrjim is offline
post #6 of 9 Old 01-13-2003, 06:23 AM
HNick's Avatar
Oh - I gotcha - I've never done this, but I sorta recall that that's what xtra link2 is for. They make an expansion unit for multiple rooms. HNick
HNick is offline
post #7 of 9 Old 01-14-2003, 05:30 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
The IR MicroLinks are receivers and are wired in parallel not in series. When using a connecting block such as the 791-44, you can wire as many as 12 receivers in parallel. Any more than that and the noise level becomes high enough that you get faulty communication.
..Doyle
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #8 of 9 Old 01-15-2003, 04:11 PM
MGotcha's Avatar
If you want an inexpensive solution using only one receiver sensor, check my response in another thread:
http://www.avsforum.com/avs-vb/showt...hreadid=212254
MGotcha is offline
post #9 of 9 Old 01-15-2003, 06:31 PM - Thread Starter
vfrjim's Avatar
Thanks Doyle, I really did not want to use a RF retransmitter and just wire an extra MicroLink.
Jim
vfrjim is offline
Closed Thread Remote Control Area
