Discrete IR code list for nVidia Shield TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 09-07-2015, 08:08 AM - Thread Starter
dalto's Avatar
Quoted: 1242 Post(s)
Liked: 634
Does anyone have the IR codeset for nVidia Shield TV?
dalto is offline
post #2 of 32 Old 09-08-2015, 01:45 PM
bryansj's Avatar
Quoted: 1419 Post(s)
Liked: 645
I used this one for getting Hex codes into my URC.
http://www.hifi-remote.com/forums/vi...2b9cdb2366a5b2
bryansj is online now
post #3 of 32 Old 09-08-2015, 05:14 PM
mdavej's Avatar
Quoted: 2275 Post(s)
Liked: 992
In case you don't know how to use Remote Master, use the following codes with NEC1 128.126 in IRScrutinizer to generate the pronto hex:
Code:
2 	Last
2	 Exit
3 	Ok
6	 Power
7 	Stop
8	 Pause
9 	Menu
10 	Rewind
11	 Left
12	 Ch+
12	 Up
13	 Right
14	 Ch-
14 	Down
15	 Fast_Fwd
17	 Play
18	 Vol+
20 	Mute
21	 Vol-
22	 1
23	 2
24	 3
25	 4
26	 5
27	 6
28	 7
29	 8
30	 9
31	 0
33	 Shield
34	 A
35	 B
36	 X
37	 Y
38	 LeftTrigger
39	 RightTrigger
40	 LeftBumper
41	 RightBumper
64	 Language
mdavej is offline
post #4 of 32 Old 09-09-2015, 05:33 PM - Thread Starter
dalto's Avatar
Liked: 634
Thanks guys that worked great.
Here the pronto hex if anyone needs it.
Spoiler!
dalto is offline
post #5 of 32 Old 09-10-2015, 05:26 AM
bryansj's Avatar
Liked: 645
As noted around the web... Not all of the commands here are enabled on the Shield. The bumpers and triggers aren't working (or didn't work last I checked).
post #6 of 32 Old 09-10-2015, 05:30 AM - Thread Starter
dalto's Avatar
Liked: 634
Could be right. I tested all the controls used for playback and navigation and the worked. As did the discrete on and off.
I did not test the triggers, the bumpers or the a,b,x,y buttons.
dalto is offline
post #7 of 32 Old 10-30-2015, 06:12 AM
Liked: 0
Spoiler!
Excuse maybe a stupid question but I am new to this. If I understand correctly I can use these discrete codes to program my Pronto remote to work with the Nvidia. But I thought Nvidia box only communicated over bluetooth? How can the Nvidia Shield box get my instructions from the Pronto? I have a RF extender so I send the instructions from my Pronto to the RF extender that reprogram as IR codes and send the the relevant equipment. But how can the Nvidia recieve these commends if it does not have a IR port?
cederstock is offline
post #8 of 32 Old 10-30-2015, 06:50 AM - Thread Starter
dalto's Avatar
Liked: 634
It does have an IR port unless they removed it recently. The included remote is BT but it has an IR port as well.
dalto is offline
post #9 of 32 Old 11-01-2015, 10:51 AM
Liked: 0
Ok, thanks for the info! Will try your codes, thanks a lot
post #10 of 32 Old 11-01-2015, 11:54 AM
Liked: 0
I have bought the Nvidia Remote. Anyone who have the discrete code for this? For example "Back" and "Home" buttons I can not find in above list from dalto?
Name:	Skärmavbild 2015-11-01 kl. 20.52.33.jpg
post #11 of 32 Old 11-01-2015, 12:34 PM - Thread Starter
dalto's Avatar
Liked: 634
They are probably just called other things in the list. Try exit and shield, maybe?
dalto is offline
post #12 of 32 Old 05-03-2016, 03:28 AM
twinturbo11's Avatar
Quoted: 79 Post(s)
Does the Samsung TV remote (Which controls many other devices) able to control an NVidia Shield ?
twinturbo11 is offline
post #13 of 32 Old 05-03-2016, 06:22 AM
bryansj's Avatar
Liked: 645
Yes, if you use HDMI CEC.
post #14 of 32 Old 05-03-2016, 06:49 AM
Quoted: 79 Post(s)
What if my Shield is connected to a Marantz Receiver (SR7010) which is connected to my TV? Would CEC still work then?
post #15 of 32 Old 05-03-2016, 06:52 AM
bryansj's Avatar
Liked: 645
You can try. You might need to use the Marantz controls and (if the AVR supports CEC). The other option is to buy a FLIRC and connect it to the SHIELD. With that you can use any remote to control it.
post #16 of 32 Old 06-01-2016, 12:26 PM - Thread Starter
dalto's Avatar
Liked: 634
Has anyone else noticing the shield dropping rapid IR commands?
It is only noticeable for me when doing something like trying to arrow up or down through a long list but it seems like it drops some of the IR commands if they are delivered too quickly.
At first I thought it was an issue with delays but it doesn't seem to be, at least not in the conventional sense. I had to add an unreasonably long delay in order to get all the presses recognized.
Just wanted to see if anyone else is seeing this in case the issue was somewhere else in my setup.
I am also wondering if this slowness is why they still haven't implemented most of the buttons over IR. a, b, x, y, the bumpers and the triggers still don't work.
dalto is offline
post #17 of 32 Old 06-01-2016, 12:44 PM
bryansj's Avatar
Liked: 645
I've had some issues with it hitting too many repeats. I've moved on to a FLIRC and just use a couple of these hex commands.
post #18 of 32 Old 06-01-2016, 06:26 PM - Thread Starter
dalto's Avatar
Liked: 634
A FLIRC is a good idea. Since I primarily am using it as an occasional media player I added an extra panel and I am using the KODI IP commands which work well for now.
dalto is offline
post #19 of 32 Old 12-23-2016, 10:13 AM
Liked: 0
Spoiler!
I have tested most of your hex codes and everything works fine except the UP command. For me it worked the same as the Menu command even though the CRC details are different. Have you had the same issue?
steve in beaumont is offline
post #20 of 32 Old 12-24-2016, 09:52 AM
mdavej's Avatar
Liked: 992
Posted code for UP is correct. Whatever the source of the problem, it isn't the code.
mdavej is offline
post #21 of 32 Old 10-02-2017, 08:28 AM
Liked: 0
I'm looking for "Voice Search" button HEX code, does it exist ? and does it possible to have this button on Harmony remote ? (I'm using external USB microphone in webcam)
PeterMac83 is offline
post #22 of 32 Old 10-02-2017, 07:14 PM
mdavej's Avatar
Liked: 992
Voice search sends no code. It turns on the mic on the controller and tells it to listen for commands. Such a command would serve no purpose on any other remote.
mdavej is offline
post #23 of 32 Old 10-04-2017, 03:21 AM
Liked: 0
So there is no chance to have this command on Harmony remote ? so for what is this HEX command does it mean it's not supported on Shield via IR ?
Why do you think that command would serve no purpose on any other remote ? it would if someone use external USB microphone.
I really wish to have it, I use PS3 microphone camera microphone and would be great to have option to start voice search on remote not only navigate on menu to turn it on for listening. Voice search work on my keyobard which is WinStart key.
post #24 of 32 Old 10-04-2017, 04:02 AM
bryansj's Avatar
Liked: 645
The command turns on the microphone on the controller. The remote you are using would first need a microphone, then a way to communicate the sound to the Shield.
They are supposed to be releasing a microphone device (called a Spot) for the Shield. That will be the solution for adding voice commands.
post #25 of 32 Old 10-04-2017, 11:15 AM
Liked: 0
I do not need any other microphone, as I said before I m using PS3 Eye camera microphone which work fantastic, but would be great to have also Voice Search button on remote to start listening without have to navigate on screen on search bar.
Spot microphone for sure will be better but will not be cheap.
So this command do something or nothing, you said it will turn on microphone on joypad controller, mdavej said do nothing do to send code
post #26 of 32 Old 10-04-2017, 11:55 AM
bryansj's Avatar
Liked: 645
There is no code for it. It's basically a physical mute button.
post #27 of 32 Old 10-04-2017, 01:31 PM
Liked: 0
Not good so only solution looks like is to have Harmony remote with Bluetooth and add Windows computer into Shield Activity and add WinStart button right ?
As I said from my keyboard Logitech K400 WinStart button work as Voice Search button
post #28 of 32 Old 10-04-2017, 01:37 PM - Thread Starter
dalto's Avatar
Liked: 634
If you want to trigger it from your PC you could run eventghost on it with an inexpensive IR receiver.
dalto is offline
post #29 of 32 Old 10-04-2017, 04:40 PM
Liked: 0
You mean external IR receiver connected to USB port on Shield TV ? If yes could you give me some recomendations which worth to buy. Thanks.
post #30 of 32 Old 10-04-2017, 07:22 PM - Thread Starter
dalto's Avatar
Liked: 634
I meant for your windows PC. You could then send the key press from there.
dalto is offline
Reply Remote Control Area
