Yamaha Receiver + Marantz RC5200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2003, 11:43 PM - Thread Starter
coolposter's Avatar
Hi All,
I'm using a Yamaha A/V receiver which has a RS-232 port. Can I use the RC5200 to download information from my receiver?
BTW, just checked Yamaha's site. They've prodived a list of RS-232 code and IR codes. How do I use them?
coolposter is offline
post #2 of 3 Old 01-21-2003, 02:32 PM
HNick's Avatar
HNick is offline
post #3 of 3 Old 01-22-2003, 06:05 AM
AnthonyP's Avatar
the best place to start for codes is the file section at remotecentral. As for being able to do RS-232 codes the answer is no. But with the newer Yamaha that does not tend to be a problem
AnthonyP is offline
Closed Thread Remote Control Area
